Digital Recorder and Video Sync
I'm thinking about retiring my old MD recorder and using a digital recorder for weddings. I've been reading a lot about the Zoom H4's audio sync issues, but has anyone used the Sony PCM-D50 or the Tascam DR-1 with video and tested them for sync?
Basically what I want out of a unit is built in mics in case I can't plug into a board, mic and line level inputs, and decent sync over long periods with video. Hearing your experiences would be very helpful. |
Of the recorders I listed (or any I didn't) which seems to do the best job of keeping sync? Anyone know? |
Without timecode sync connecting both devices, there will prety much always be a difference between the camera clock and the recorder.
One may be slicghtly slow and the other slightly fast, any way you won't have 'perfect' sync. Typically it is less than half a second/15 frames per hour. At a wedding you won't be able to slate ;-) or even snap your fingers, so you have to eyeball it or find some common reference. Unfortunately I don't do weddings etc. so I don't have any tips/tricks that would work there. George/ |
the least drift
Since we've established that the only way to hold sync past 20 minutes is to physically sync camera to recorder (via TC out) and this method is impossible for me, then which of the above recorders or any not listed with comparable options/quality/price seems to drift the least?
My point is this - if you're going to have to do a correction anyways, does it really make a difference if its a 45 frame or a 180 frame correction? (this is assuming that you have the capability to stretch & squeeze an audio track in your favorite post environment, you're not cutting and re-syncing every 10 minutes) If all this sounds right for your situation, you'd then be thinking about which recorder in your price range has the features you want. |
Less drift is better. But, there really is no known answer for the question which external recorder will be the closest match to my camera's clock... There can be variances within brands. But, if there is a known problem w/ sinc with the zoom units...I would want to avoid going that direction. I haven't used any of these units to make a recommendation: Looks like these are your options in the $300 - $600 price range. Choose wisely. Tascam DR-1 Edirol R-09 Olympus LS10 Sony PCM-D50 Marantz PMD 660 Fostex FR-2 LF |
The least expensive solution I know of off-hand is to use the Tascam HD-P2 recorder. It accepts composite video from your camera output and slaves its sample clock rate to the black-burst sync signal embedded in the video stream. If you can't connect your camera to the recorder, it get's more dicey and none of the ones you mentioned will hold perfect sync for an hour or more. It may not be a total disaster - many NLEs allow you to make minor length adjustments without affecting pitch and if your audience is viewing the program on the small screen spot-on sync is less crucial than it would be for the movie theatre but it's definitely going to be a fiddly PITA to get it right. |
If you can confidently sync the whole track in post, in one go, you don't really need to worry over small differences in the clock generators between models.
I posted a procedure for syncing in post here: http://www.mfbb.net/myvideoproblems/...s-about25.html a while back,using free programs. If you have access to Audition, for example, it's even easier. As the others have commented, the problem is likely to occur to some extent or another, whichever unit you go for. |
On the other hand, I wouldn't personally guarantee these results for every Sony. I think that anyone who lays down the money for a digital recorder should plan on stretching or shrinking the audio file--and it's no big deal to do that. |
My experience has been more positive. When I capture live events, I use Sony HDV cameras with up to 85-minute-long tapes. Sound is recorded to my Alesis HD24. Most of the time there is no noticable drift between audio and video. Sometimes (maybe 20% of the cases) I have to break a clip in multiple pieces and them of them around on the timeline, by ONE OR TWO FRAMES, to get them synch'ed again. Call me lucky, but the thought of having to deal with drift on the order of dozens or even hundreds of frames is just unbearable.
- Martin |
Interesting enough, some camera's are actually slightly out of A/V sync. |
For what it's worth - I used the Sony D50 recently as a "room" recorder at a music event where primary audio was going to a Fostex PD606. The 606 has an internal TC generator; the D50 does not. They stayed in sync with each other over a take of about 45 minutes.
Now in a few days I get to find out whether they stayed in sync with the non-TC cameras we shot on . . heheh, fun. |
In a two hour show, my iRivers drift maybe 5-10 frames at the end. Fixable, but annoying. One thing I saw however, was an option to sync audio to 29.97 NTSC in Apple's Soundtrack Pro 2. I'd sure like to try this, but soundtrack never wants to play with me; it's easily the buggiest program in FCS2 and crashes repeatedly. Has anyone used this feature before, and would it solve some of the problems being described here?
I use a Zoom H2 all the time for my videos and it is about 0.3 sec too fast over the hour. I use Avisynth for most editing and it's very simple to correct the drift with these two lines in the script:
ResampleAudio(47996) AssumeSampleRate(48000) All I have to do is trim the H2 WAV files to match the camera audio startpoint and then run this script: directshowsource("SANY3406.MP4") Tweak(sat=0.8, Hue=0) video=last lf_rf=wavsource("ljud\SR002R.wav") c_lfe=blankclip(lf_rf) lb_rb=wavsource("ljud\SR002F.wav") sound=MergeChannels(lf_rf,c_lfe,lb_rb) AudioDub(video,sound) ResampleAudio(47996) AssumeSampleRate(48000) Here all four mic capsules are used to get a nice 6 channel WAV that later can be fed into an AC3 encoder to get surround sound. Just note that If the video is really long you may get past the 2 GB WAV file limit. Also there is no need to worry about pitch after the resampling. At 440 Hz you will get one beat every 30 sec. if you (for whatever reason) mix the original with the resampled WAV. That's not audable at all and much less than any piano tuner can achieve. Once you learn to stay away from the digital recording level and just keep the H2 at medium senitivity it's a great recorder. Even works handheld if you can keep your fingers absolutely still. |
I was giving serious thought to getting the H4 truthfully. it's the only pocket sized recorder with XLR in's which is what i want. where is this link that talks about the zoom's anyway?
