Live Event Mixing
My experience is mainly in booming into a recorder on-set for dialog and sounds, and also editing, but not much mixing yet. I just got a gig mixing at a live parade this weekend. There are 2 mics setup apart from each other as it passes by, plus I have to mix in some speech from other mics.
Would I just keep the parade volume the same by basically crossfading as it pases by riding levels, and then just have a set level for the talking/commenting etc? Or another method.. If anyone has done this type of recording before pls advice any techniques. Any feedback from someone more experienced at such a thing would be much appreciated!! :) |
What are you mixing to? How many output channels? Are you just doing a recording or feeding a PA system as well?
Generally speaking I would just ride the levels of the two mikes for the parade passing, don't cross fade them. If you're doing a stereo mix this will be the foundation of the sound field. The parade mics should be panned hard left and right matching the perspective that the camera is seeing. Any vocal mics should be panned either center or close to center. Just dip the parade tracks if necessary to make room for the speaking parts. Just be sure you are in a good position or have sufficient video monitoring to see the events unfolding so you can be ready to make your fader moves. Your moves should be smooth and not overly extreme so the elements in the mix don't jump out at you abnormally. I've found its a good practice to try to put your finger on the fader of the next event before it unfolds. That way you don't have to look down at the board at the last instant and possibly miss fading up the person talking. Hope this helps! Bernie |
thanks Bernie, this helps alot. I believe to the camera after the mixer. I think there is 2 mics set at the 2 commentaries and 2 facing the parade. (maybe directionally following Im not sure) Most likely 2 channels out of mixer and into the cam, no pa.
So no crossfading as it passes, just move the faders down at once as it passes to keep the levels the same? Thanks!! |
Have fun! Bernie |
One more thought. Place your mics so individual instruments of the marching bands aren't blasting into them as they pass. Think of it as recording a band that happens to be moving.
But you probably wouldn't be making that choice yourself - if it's live to broadcast then there is no "later" for the vox/music mix, and follow B's suggestions. If live to tape then the director should be telling you whether to mix or go iso. Quote:
It is *very* helpful to know the primary camera positions. You need good micing at the positions to match the shots. If you're on com with the director to the cam ops you can get his/her ready cues and know what camera is next. And also find out from the director or talent whether they plan to do features like "and here's the Washington High School Marching Ensemble - let's listen to them". |
good advice. thnks heaps.
The crowd mic'ing and instrument recording considerations are prime ideas. cheers |
just 1 more question.. would a compressor on the band mics help keep em level? And if so, would I monitor the final mix w the compressor audible in my headphones?
Bernie |
Very rare to mix for live-to-broadcast on headphones. You've not shared much about the circumstances & approach & market for this project.
Usually a parade is going to be mixed on speakers in a remote truck. 2nd choice would be for you to set up in a room that's acoustically isolated from what's going on in the parade and mix on speakers. Doing a music/announce mix live on headphones is a problem because cans will tend to overemphasize the announce, meaning that the folks at home will hear less of the announce than you want them to. Live to tape - it's a different deal if you are recording music and announce iso to two channels for later mix (on speakers), and headphones can be fine for that. |
Bernie |
thanks for all the help guys. Was mixed down to 2 mono tracks in a truck and was a breeze. Cheers
