-   -   Need help with a kit I'm making up. (https://www.dvinfo.net/forum/all-things-audio/119325-need-help-kit-im-making-up.html)
Scott Delish April 13th, 2008 10:42 PM
Mic/Boom stand: http://www.bhphotovideo.com/c/product/2904...Boom_Stand.html
Audio Technica AT897:
http://www.bhphotovideo.com/c/product/4008...Microphone.html
http://www.bhphotovideo.com/c/product/4815...Microphone.html
I can't tell the difference between these two other than the little cord that's included in the second link and costs shipping and handling.
Wind muff:
I need help finding a cheap effective wind muff
XLR Cables:
Not sure about these cords, so I need one that is at least 25' (ft) long. So if anyone could recommend a brand or just a good cord let me know please? Like I said I don't really know a whole lot about this, so help is very much appreciated and thanks every for answering my lavaliere thread.
Scott Delish April 17th, 2008 08:44 AM
Any help with the wind muff and XLR cable please? Sorry for the bump.
Colin McDonald April 17th, 2008 09:35 AM
I use Van Damme cables but I don't know if that's just a UK thing.
For wind protection Rycote
http://www.rycote.com/products/full_...em/windshield/
is the standard but is expensive. I try to get away with using the supplied foam shield and a Dead Cat with my Rode NTG-2 but beware
http://www.dvinfo.net/conf/showthread.php?t=119442
There are some also cheap Rycote imitations - do a search.
If you are fairly new to XLR cable matters could I suggest you have a look at this:
http://stagecraft.theprices.net/gallery/cablewrap/
It's quite easy to damage long audio cables if you don't know how to coil them properly.
Scott Delish April 18th, 2008 09:43 AM
You reckon this would be good for cutting out wind for a Audio Technica AT 897 mic? http://www.bhphotovideo.com/c/produc...hield_Kit.html
Jason Robinson April 18th, 2008 03:30 PM
that will work but...
holy crap that is expensive! I guess the real question is, do you make your living (or will you) by using this equipment? If so, invest in the higher / better quality. If not and you are "testing the waters" then try something that is less of a gamble. I bought a fury cover on ebay for my AT897. Works pretty well (still get rumble when pointed head on or to the side of a 30 mph wind (mountain top recording).
I can point you to the seller for the one I got (it is a business store). It was about $27 for a fur cover for my AT897 and for a hand held Azden.
Scott Delish April 20th, 2008 09:43 AM
I'll be using it for some outdoor shoots, small videos, possible outside graduations etc.. etc.. 25 mph or less winds.
Renton Maclachlan April 20th, 2008 01:27 PM
For great wind cutting, check out blimps at:
http://stores.ebay.com/DV-Shop23
Also discussion re these Indian blimps on thread at at:
Scott Delish April 21st, 2008 12:30 PM
Will this softie fit the Audio Technica AT 897 microphone? http://www.bhphotovideo.com/bnh/cont...=256524&is=REG
also do I just put the mic in there then mount it on the boom pole or what? Can anyone help me out with this please? It's the last think I have to know before I place the order, thanks a lot guys.
Marco Leavitt April 21st, 2008 12:44 PM
Softie is the way to go. Call B&H and ask which model for the AT897. The size of the hole is critical. Lightwave and K-Tek also make versions that are well regarded. Haven't used the K-Tek, but I prefer the Rycote softie to the Lightwave. Not knocking the Lightwave. Lots of people like them, but when I've compared the two, the Rycote seemed like it had better construction to me. Also, I have a recent catalog from B&H that shows a new slip-on type windscreen made by Rycote that doesn't have fur. Don't know anything about them, but it's worth investigating. Don't settle for an untried off brand. If the fur gets matted easily, it will interfere with the effectiveness of the interference tube of the shotgun. While the things look simple, there's more to them than seems obvious.
Jason Robinson April 21st, 2008 01:51 PM
closed
B&H is closed till 9pm tonight so you will have to wait till then (I've been sitting on a shopping cart order that I have to have by Sat so I'm anxiously waiting for them to open as well).
