10-conductor breakaway cable
I've been looking into having a 10-conductor breakaway cable built that could hold my two XLR outs, 1/8" mini return and an XLR return (so I could run an on-camera mic or wireless receiver through the mixer). The cable can be built - the problem is trying to find a 10-conductor connector that is big enough to fit over the cable and doesn't cost $200. The breakaway is more important than the XLR return so I'll just get a regular cable made if it can't be done.
Any thoughts or ideas? If it makes a difference, I'm using a Sound Devices 302 mixer. Thanks, Mark |
EIJ(?) had a standard 10 pin connector, but its pretty big. used to be used between cameras and VHS recorders. the most conductors is 8 pins on a Nuetricon speaker connector, but its bigger then the 7pin most folks are used to. why not just keep that mic local to the mixer on a short boompole if all you are looking for is ambience/uncritical NAT sound.
I had to buy, OK had is a stretch, a couple of those hirose connectors and the connectors themselves were $40 each! I found them at DigiKey in the US. Even with my soldering station, and experience soldering 100 pair cables in the military, I found it very tough to get to some of those inner pins. I did manage to make the cable I needed, but when I needed a new cable, I broke down and bought the Remote Audio version. It does suck that the cables cost so much, but when I compare the cost vs. frustration, it was worth it for me.
Wayne |
Hi Mark............
Somewhere near where my Dad was born, if I'm not mistaken.
To business: Excuse the ignorance. I do connectors, I do cables, but what, exactly, is a "breakaway cable"? The problem I'm having is trying to figure out a fix without actually knowing what the problem is. Give me a hint here. CS |
These are called Betacam Breakway Cables because they first emerged for newsies using betacams. http://remoteaudio.com/cables.htm#betacam and the model you want is CABETACFP33. |
Just to clarify (I typed that first post on my Nintendo Wii, so editing text is a bit of a hassle), I'm having the cable built by an audio mixer I work with. He has a 442 and builds breakaway cables. He does great work, I save a bit of money going through him and he does free repairs if the cable gets damaged.
Since he does custom cable work, I figured I'd see if I can send a few 'extras' down the line (I was looking into sending a BNC video line, but putting that in a breakaway requires a $1000+ connector! Seriously!). The reason I wanted an XLR return is for when I'm shooting sports - I've had very good results putting wireless mics at each end of the court/rink/field and a shotgun on the camera. If it's not possible to put another XLR in a breakaway, I'll just get the basic 2 x XLR, 1 x 1/8". I suppose this is an advantage because by using the same connector, I can borrow/rent someone else's cable if something ever goes wrong with mine. I just came across these, which might work: http://www.trewaudio.com/store/produ...&cat=80&page=1 http://www.trewaudio.com/store/produ...&cat=80&page=1 Thanks for the replies. |
