-   AJA Io and Ki Pro (https://www.dvinfo.net/forum/aja-io-ki-pro/)
-   -   Configuring a Canon EOS C300 and an AJA Ki Pro Mini for 1080p 23.98 recording (https://www.dvinfo.net/forum/aja-io-ki-pro/506410-configuring-canon-eos-c300-aja-ki-pro-mini-1080p-23-98-recording.html)
Jon Thorn March 26th, 2012 07:21 PM
Today a customer contacted AJA Technical Support because there was some confusion on which camera settings on the Canon EOS C300 needed to be set in order to extract 1080p 23.98 fps from the camera's 1080i 59.94Hz output when coupled with the AJA Ki Pro Mini. I thought it might be beneficial to supply some information here for the benefit of Canon/AJA users who might wish to do this.
Canon EOS C300 settings:
SDI Output>HD
NTSC/PAL>NTSC
Bit Rate/Resolution>50 Mbps 1920x1080
Frame Rate>23.98P
SDI Rec Command>On
Timecode>TC In/Out>Out
User Bit>Output Mode>Pulldown
Important information regarding 1080p 23.98 fps extraction from 1080i 59.94Hz can be found on page 79 of the Canon EOS C300 user manual. The user manual can be found on the Canon website at:
http://gdlp01.c-wss.com/gds/3/030000...0pl-im2-en.pdf
AJA Ki Pro Mini settings:
CONFIG>Camera Data>Canon C300
Information regarding the specific interactions between the AJA Ki Pro Mini and the Canon EOS C300, with respect to the extraction of 1080p 23.98 fps from 1080i 59.94Hz, can be found on page 48-49 of the AJA Ki Pro Mini manual. The user manual can be found on the AJA website at:
http://www.aja.com/pdf/AJA_Ki_Pro_Mini_Guide_3.0.pdf
With any AJA product, if you have questions, don't hesitate to contact AJA Technical Support via phone or email for assistance.
Hope this information is helpful,
Jon Thorn
Senior Product Manager
AJA Video Systems, Inc.
