Pal to Ntsc using PP2 & Encore2
Hi there
My apologies if I have put this post in the wrong thread. Can anyone tell me the best way of converting a PAL Project in PP2 and converting it to NTSC. I have already edited the wedding in PP2, and was wondering whether it's just a case of changing the output settings to NTSC before I import it into Encore 2. The wedding disc is going on to Trinidad as the wedding was shot in England, U.K. Hope you can advise Thanks Wayne |
I don't know that encore can do that but there plenty other software on the web that can do it. Just google it (*__*)
IMO the only software that gives pro results is "Algolith Algosuite"
It's a plugin for After Effects. |
As the others have said, there isn't really a "best" way to do this in PPro2 ... Procoder does a reasonable conversion if you have access to that.
I said Procoder is "reasonable" and I stand by that (... it does more a bit more than just frameblend by the way).
Mocomp is not a magic solution - it can be great but with problem footage can have nasty artifacts. The Mocomp plugins available for avisynth are a good alternative to Algolith, and are free. |
