Field Order question - Lower or Upper first??
Can someone smarter than me please give a definitive answer to this:
How should I export? With upper or lower field first? Some say it's different for PAL & NTSC, others say it's not. Some say it's different for DV & HDV, others say it's not. I shoot on a Z1 & a V1 in 50i and export to 50i at HDV. Sometimes I shrink to SD at 50i. Othertimes I de-interlace to 25p in premiere pro or I shoot in 25p on the V1 or CF25 on the Z1, which I'm failry certain I'm supposed to set to no fields. But when editing interlaced footage, what the heck do I tell it to do? |
HDV is UFF (upper field first), SD is LFF, unless you use Matrox, which is UFF.
Yeah, keep it interlaced with upper field first all the way through your editing cycle to maintain quality. Then at the very end, you may choose to export more than one flavor from that interlaced source:
1) A DVD for your friends, which needs to converted to interlaced, lower field first 2) A quicktime file for the web: convert to progressive (no fields) 3) Blu-ray, where you'll want the original interlaced upper field first again. So just leave the render format decision until the very end. Work with native format until then. |
So...you need to separate the two terms..."SD" and "DV" for purposes of this conversation. The Matrox DV codec is lower field, or it wouldn't be DV spec, all other SD codecs Matrox, Avid, Media 100, and anyone else has are upper field first if they are following suit with broadcast standard equipment. |
