Problem w/ Exporting to DVD in Premiere Pro
Hey guys, I made a movie that has different things frozen in mid-air, and many times I used garbage mattes to do this.
Well, I just burned the DVD using 'Export to DVD' in Premiere Pro (Version 7, the one right after Premiere 6.5....), and I was watching it on my TV.... the edges of the garbage mattes are visible! It's a solid black line around the edges of the matte... Grrrrr.... Is there anyway to remove those black edges on garbage mattes when exporting to a DVD in Premiere? Oh, and Is there a way to make 4:3 looks 16:9 without it stretching? (So instead of it stretching, I want the black bars on top and bottom)... Also, what are the best settings when exporting a DVD? Thanks, Colin |
In all my Premiere Pro experience, I've never seen or heard of any problem like the one you're describing with your garbage mattes showing up. Exporting to DVD from Premiere Pro has always been pretty simple, and if it shows up on the preview window, it will show up on your DVD. I have found though, that with larger projects, its usually better to export a movie file and then export to DVD from that instead of a project full of layers. I'd say to try that and see if that fixes the problem. You could do it quickly by rendering only a small test portion to see if that fixes the problem. If not... well, I'm not too sure.
Its also super easy to create a fake letterbox in Premiere. Just open up the titler and draw two black rectangles that stretch across the frame. One at the top, and one at the bottom. Place that in your top layer, and kablammo! Instant letterbox. |
Hey thanks a lot for your reply... I will definitely try exporting as a file and then to a DVD. Thanks for the tip.
Blaghhh... I hate when you can't think of the correct terminology (letterbox instead of black bar thingamabobbers..) :) Okay, thanks again!! You were a big help! ~Colin |
1 Attachment(s)
Here is a .png Mask I made that you can just drop into your timeline.
More masks at www.kraentertainment.com |
Hi,
Another way to create a letterbox, is to choose "Clip" (type in clip to find quickly) from the effects tab, and in the effects control type in the value for the top and bottom. |
| All times are GMT -6. The time now is 10:08 AM. |
