-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   PREMIERE PRO - looking for GOOD video effects or video transitions... PLUG-INS (https://www.dvinfo.net/forum/adobe-creative-suite/94566-premiere-pro-looking-good-video-effects-video-transitions-plug-ins.html)
Greg Schlueter May 21st, 2007 09:24 AM
Greetings.
Many moons ago I used PP with Canopus (bundled with capture card, etc.), which had a host of awesome video effects and transitions that plugged into PP. Now, a few editing systems later-- not using the Canopus Card (Etc.)... I don't have access to those but would like some good recommendations for some GREAT/ PROFESSIONAL LOOKING video effects/transitions plug-ins for PP2.
THANKS!
Ron Link May 21st, 2007 10:26 AM
I have a Matrox RTX 100 card that I use with PP 1.5, and when I installed PP2, I found that it works, but it will not work with the Matrox card. So the effects that the Matrox card provides are not available. However, I have largely stopped using the Matrox effects some time ago, finding that I can better control the effects I normally need without using it. So I just use what PP came with, and in the vast majority of cases, it suffices. (Most of the productions I do are TV ads, by the way.)
If I want a high-end looking effect, I create it in AE and import the resulting clip into PP2. Normally, that is what I will do for introductions to productions, and/or closings, but for the main body of the production, I use very few FX, and as for transitions, a simple dissolve is by far the best transition to use, IMHO. It does not distract from the production, and is normally not even noticed, which is the goal, I think. When you try to impress the audience with every cool effect you can find, then it becomes not just distracting, but annoying. Simple is best in my book.
Shawn McCalip June 1st, 2007 06:48 PM
Have you seen the Sapphire plugins by GenArts? Its quite expensive at $1600 US for the whole package, but they're super sweet and definitely professional-looking.
I know Boris Red or Boris FX can function as a Premiere plugin too, so that might be something to check out. Personally, I'm not impressed with their appearance. I know Boris Red can generate 3D text, but to me it just screams early 1990's when 3D started becoming more prevalent... Best of luck to you!
