-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Google Video, You Tube - Best export settings? (https://www.dvinfo.net/forum/adobe-creative-suite/90091-google-video-you-tube-best-export-settings.html)
Steven Gotz March 29th, 2007 09:45 AM
I stand corrected.
Michael Barrette March 29th, 2007 10:40 AM
I'll also be chopping some of my video as it's shot in HDV and I'll be going to 4:3
I have after effects so I am thinking that may be the best program to handle this in? Or is premiere sufficient for this? or another program ideal? Any suggestions on that?
Steven Gotz March 29th, 2007 10:50 AM
I do it in Premiere Pro. It is simply a matter of creating a project using a smaller frame size and importing the HDV material into it. I find that the video I use for a 60" HDTV is different that the stuff I want on a video iPod for example.
Use an interview or discussion between two people. You use a 16:9 shot to capture them both, sitting facing each other. Great for the TV, but bad for the tiny screen. So you use the material in a 4:3 SD project and you find that you can isolate each person by using the full resolution of the HDV in the smaller frame. It feels like you zoomed in but you merely failed to zoom out.
I have taken this to the next level and created a 320X240 project and used HDV footage. Talk about zooming in!!!
Michael Barrette March 29th, 2007 02:27 PM
Interesting, basically shoot with one boring angle, then play around with it and you'll have multiple angles and shots for a web video...
I would think about doing this in After Effects, since it sounds like it is more effective at resizing the video... at least if you plan on using it for SD output at some point for DVD or whatnot...
Steven Gotz March 29th, 2007 04:22 PM
Not to change the topic, but HDV in After Effects has known issues (without Aspect HD).
http://www.adobe.com/cfusion/knowled....cfm?id=332583
Michael Barrette March 29th, 2007 08:11 PM
More and more I hear about Aspect.. sounds pretty important.
Then again, people that are using Aspect are also using ProCoder it sounds like for their encoding... that's an extra $1k just to make premiere work properly with HDV... I wasn't expecting this when I decided to go with adobe as my suite...
This new speededit software sounds pretty cool... $400 and it's an entire NLE with the fastest transcoding available... so far extremely good reviews...
I'm determined to get a workflow here that is extremely efficient and extremely effective but not looking at throwing money at the problem if I can avoid it... the quicktime encoder may be the trick for web video... I am having severe problems getting my HDV into a format that I can back it up. Won't go back to tape (cuts out halfway through transoding), looks like it will take a 12-24 hour period to get a WM9 HDV file out for a 20 minute video which is way to time consuming for me, not to mention it very likely may stop working half way through... I am on Vista, probably going to change to XP in the next day or so and see if that helps...
Juan Parra March 31st, 2007 03:10 PM
Compression Settings for Youtube
Check few different settings for different encoders:
http://www.squidoo.com/youtuberight/
Steve Young May 1st, 2007 02:59 AM
I try now to avoid You Tube/Google Video after discovering Brightcove - its free and growing in popularity and I have received tons of emails from people asking how I got such good quality on my vids - sure it has something to do with the way Brightcove encodes but also because I convert from HDV Cineform using Sorenson
Here is a link: http://www.brightcove.com/title.jsp?...nnel=712914570
(The music is crazy watch out! Thats the dutch for you!)
