Linking Audio
I have a film I shot where Audio and Video were run seperately. I want to be able to link the synced audio and video in a subclip but don't know if this is possible. I can't find much help in the help files. I am running Premiere Pro 2.0.
Jared, welcome to DVi!
It is not only possible, it's fairly simple. Just import the audio as an asset, then put it on a separate track under your video, and move it left-right until it's perfectly synced. It'll take a while, but if you look for a point on the video where a specific sound/noise has been made, that will help. If you do have audio on the tape (even if it's low level or noisy) then you can do it in Audition, that's how I like doing it because I can do more complex audio editing/corrections, but it's a bit more complicated. |
linking audio
Jared Ervin is right in how to get it synced but then you should highlight the Video and Audio Track and right click and go to link audio and video (I believe this is the option I can not open Premiere right now to check for sure) then the two will be like one clip that you can move and edit as one instead of two separate clips.
I'm having no problem syncing the audio on the timeline. But I have 15 days worth of material and don't want to be forced to leave it all on the timeline. I would like to be able to make subclips of the synced audio that I can store in the bins and access when I begin to cut the footage.
It is a pain to be limited to only having seperate audio and video files linked on the timeline. All the stuff is there - slates for syncing, footage and audio - only problem is they are two seperate files. Just need the linked and stored that way in the bin. |
You could just create a new sequence for each clip, and then store those sequences with the link audio in a separate bin. And then just hide all you other files in separate audio and video bins.
I thought of that, do you think it would slow the playback down? I guess I could always try and see what happens.
Well I've managed to cut an entire 100min feature in premiere where video and audio were recorded separately. Premiere does not make it easy for this to be done.
I had to create a new sequence for every take we did. Totaling well over 200 sequences. We did this because there was no other way for us to link the video and audio while allowing us to remove the full clip from the timeline. At first we thought this was going to work fine, but nested sequences require extra rendering to be played back. Another annoyance is when you double clip a clip it opens in your source monitor window. You double click a sequence it opens the sequence, whether it is in the bin or on the timeline. We had to drag our sequences into the source window to be able to view it there. Aside from those little annoyances we found even more difficulty when we got into our post audio and color correction. We were trying to work with Universal Studios but they use Pro Tools, as any established post house uses. We needed to export an OMF or an AAF file for them to be able to read it. Automatic Duck made an OMF export plug-in for Premiere but that was discontinued, so we went with AAF export. Unfortunately AAFs do not support nested sequences (keep in mind our entire film is nested sequences). Another thing is we shot with the HVX200. It could just be me or could actually be the camera, but the timecode starts from zero each time the card is switched, the reel number stays the same which makes the timecode worthless because the EDL is now unusable and we can not even reassemble the audio in Pro Tools via the EDL. The next thought was we need to do our color correction. I open my project in After Effects and choose to open my timeline...wait, what's this? After Effects does not support nested sequences from Premiere either? I can't even open the timeline. Now it is taking me forever to unnest every single clip. Please tell me that CS3 allows you to do real subclipping. (i.e. Sync up audio and video on the timeline, drag it to the bin and have those files connected. Final Cut Pro does this and this one feature made me seriously consider scraping premiere all together.) - Anyone know anything about this? Also, we finally got the AAF file to export somewhat correctly but Pro Tools only sees one channel of audio to import out of the 7. What's up with that? |
Jared, Not sure this method will help or not, but you can also use the
Export, to movie, output video and audio and have it all come back into the project automatic.... This way you can have the sequence with linked video and audio...on the time line. If after the fact you need to change the audio on this linked sequence then you just right click on the video on the timeline, un link the video/audio, left click any were in the timeline window where you wont select any material so it un selects the selection, then left click on the audio track for further editing... It sounds convoluted, but try it, its much easier to actually do than set here and type out the instruction...... :-) |
That is an idea - only problem is you begin to double your file size or the HDD and it takes even longer (waiting for the files to export), especially when you get into the 3 - 5 min long takes and especially if you are working with HD.
I did finally notice the ever obvious option to remove unused content from your project. Project > Remove Unused. I had just spent an evening talking about how Avid has this option, then I found it. So I guess that is a bonus.
Now I would love to be able to tell Premiere which audio files I wanted it to conform first. |
