avi codecs
I am trying to save space on a project i am working on for fun and i need some help. I have a bunch of clips that i would like to use that are encoded with divx. When i import them into premier they preview fine but once i put them on the timeline no video shows up at all. in the past i just used vegas for similar projects but i have no desire for that this time. The reason i want to encode it is because i am going to be recieving some of the clips over the internet which would make it a very slow process if i did it with unencoded avi files. so my questions are:
1. is there any way to get divx to work correctly with 1.5. 2. if not what codec can i use to encode my files that will be no hassle to edit with in premier 1.5 |
MPEG-2 is the best lossy codec to archive in, as it is so widely supported. Indeed, many applications can edit it natively.
i might consider that but im really looking for a codec for avi files. from my experience other file types besides the native one for the program take a long time to import and then you have to re render it later. Plus mpeg 2 is still a little larger than what the avrage avi codec gets it down to i believe. unless i have no idea what im talking about which is possible.
For decent quality (but largish files) a mjpeg codec like PicVideo or MorganMultiMedia works well.
Xvid is arguably better than DivX (Doom9 did a codec shoot-out recently) ... and ran fine for me on PPro1.5. |
You might take the clips you receive via the net (or DivX files you already have saved), and convert them to DV for editing purposes.
I also prefer using Xvid to DivX. |
so i did try using xvid which did not work. but i had read on another forum some thing about changing the "fourcc" to DIVX instead of xvid. i dont know exactly what this does, im still encoding it with xvid but it seems to work. i dont know why having it on divx would work while no divx files work for me at all.
I have another question though, for these files i have to render them inorder to watch them smoothly. is this because they are compressed avi files? because i know i dont have to render normal avi files. does this happen with every codec? |
Playback of DV-codec or M-JPEG codec should be smooth a silk on any system ... playback of xvid, divx, wmv etc will be a bit more dependent on your processor's grunt
| All times are GMT -6. The time now is 02:01 AM. |
