Workflow: PPro + XL2 16x9
Hi group,
Just a quick question regarding the optimum setup to edit in PPro: XL2 16x9 24p 2:3 standard; Should this be a standard 16x9 project at 29.97 or should I be at 23.93? The finished destination is always NTSC dvd, never film. Authored in Encore. Thanks - Jimmy... |
Most people who shoot 24p regular edit and export in a 60i timeline, to give the look of film transfered to tape. But sense your going to DVD i would suggest shooting in 24pa and edit in a 24 fps progressive timeline, and export real 24fps footage. Also, you usualy edit in the aspect ratio you shot in, unless you need to letter box 16x9 footage with 4x3 footage.
Wow thanks Wes. 16x9 for all components including stills, graphics and exports from AE.
You mentioned to export at 24fps. Is that possible in PPro? As a dv avi? Also, I suppose I should be exporting from AE at 24fps progressive also? Thanks - Jimmy. |
