You got it right first time Michael. So I just closed PPro and on restarting it everything worked fine, so far anyway. Thanks for your help.
Oh, sorry. Error is "The project could not be loaded. It may be damaged or contain outdated elements."
Importing it into a new project causes the same error. |
Make the program monitor full size without any distortion to the image?
I use an external NTSC monitor while editing. I sometimes like to use the program monitor in the P-Pro 2.0 workspace to view the video as it plays back through the timeline. Is there a way to make the program monitor full size (full screen) without any distortion in the image? It's difficult looking at that small preview window.
Thanks |
External monitor - full size
There are a number of video cards whereby an external monitor is connected and displays the "scrub surface" of the monitor window only. I use the Matrox Parhelia APVe card with one large DVI panel for desktop and the other connected as component HiDef. (NTSC can be in addition or in place of that). I then use the Matrox WhatYouSeeIsWhatYouGet plugin for standard def projects and Cineform's for HDV projects. There are other alternatives, but this works beautifully.
Sorry about that. What I meant is that the video transitions aren't there. Im not sure why but I chose Export Movie and saved it to my folder.
Right, but - where your transitions are supposed to be what do you see instead?
Your video footage, unaltered? Or a section of black video? Or what? |
720p has strange stutter?
I filmed about 25 minutes with my JVC GY HD100UA. It's in 720p 24. I also captured to a hard drive with hdvrack-equipped laptop.
I also used Cineform to turn my hdv into cineform .avi files. I have a one long 25 minute avi file I got by capturing via firewire. My PPro 2.0 used the cineform as a plug in. After 15 minutes, the file has like 1 seconds of dialog playing over and over like a stuck record. The picture is static. When I play the same piece in Windows Media player, no problem. The M2T files from the HDVrack laptop are fine. I used HDLink to make them into avi files, which work fine. So I have usable footage. But the other footage only has the problem in PPro2.0 I created a new project and put the file into that, the same problem. I did note HDVrack created 2 M2T files, one ending where the problem begin on the other file. So it seemed like something happened what that point, though I didn't notice anything at the time. Hard to describe... any thoughts? |
Dennis,
I had that exact same problem. Mine was 1080i Sony FX1 footage though. I wish I could help you though, I have no clue what the problem was, it just went away for me after I reconverted everything (had to for a different reason). |
I might try transferring it again, just to see if it was some odd hiccup.
If it happens when I try again, I might transfer without using Cineform, and maybe narrow down the problem. |
Well, while this problem may occur for someone else, Cineform sent me a fix for my issues with Ppro 2.0 and now I'm fine editing in it. Thanks anyway.
Audio track previews too early!
As I play through my timeline I notice the audio is playing about 1 to 2 frames before the video. It's not just the audio linked to video tracks; I set a sound effect lined up to a cut to another shot but the sound effect manages to play while I'm still on the previous shot. What's going on? Any way to fix this? It's really messing up my audio editing...
Don,
Thanks... I currently use the Canopus ADVC-100. This external unit allows me to preview playback on my commodore 1702 NTSC monitor via a modified S-video connection. http://www.retrothing.com/2006/03/commodore_1702_.html By the way... if you want an affordable monitor - you can pick one of these up for $50. Make a cable from $7. You have Tint, Color, Biightness, and contrast controls too. Makes it nice... when calibrating to color bars. ;-) These little units are nice in the field too. I do not have two PC monitors. Sometimes I like to see the full size output (say 16X9) on my PC monitor. I do not care for the small preview window in p-pro. Is there a way to get a larger preview window without distorting the image? |
Just upgraded to PP 2.0 and lost fonts
About 1/3 of the font's on my system no longer work in PP 2.0. They worked fine in PP 1.5. Most the font's I could careless about, but the tribe I work for has developed thier own font, we've used for years from print to web and video, and in PP 1.5, but now it dosen't work. It still works in Phsotshop CS2, Illustrator CS2 and After Effects 7.0. Any suggestions?
I would try reinstalling those fonts.
done that...
I first reinstalled the font.... and rebooted..... then uninstalled... rebooted and reinstalled.... to no avail
Never mind...this is a Cineform issue, not a Premiere issue.
Editing footage from a DVD, (.vob)
I got some music videos that need to intercut with my film, but I got all those on a dvd playable in every player there is. So there are no .avi or other data files. I want to edit this footage in premiere, and it doesn't play these files, but vlc does. How do I do this? Is there some fancy dvd-ripping involved and do i lose quality during the process?
whats the easiest solution? Regards |
Depends if it's copyprotected or not. If it is that's where 'ripping' comes in.
Otherwise, a "vob" file is just an mpeg2 video stream with one or several audio streams. Try changing the extention to .mpg ... that may be enough for Premiere to accept it. Otherwise demux it back to separate video and audio streams using something like "mpeg tools" in the demo version of TMPGEnc. |
Help! Help With Strange footage!
Hi All,
I took over the job of helping with an intro movie for an art festival in Southern Florida. I popped one of the previous tapes in the camera before starting to see what format it was in, because they knew nothing about any of the camera work. They just wrote, directed and produced. The tape played in a 16:9 style format, so that is what I shot. I shot my footage on Sunday, about 6minutes worth, and when we finished they gave me two tapes they already had. When I captured them today, something is wrong about the format. When captured in a 16:9 project they are 16:9 ratio, or very close, but the files need to be rendered when put into the PPro timeline. Then, after rendering, they are still 16:9 ratio, but are smaller, and must be blown up to 135% to fill the window. When captured in a 4:3 project, they do not need rendering, but maintain the 16:9 or cropped size. These were shot with a DVX100b, and the tapes are supposedly straight from the camera. Does this camera crop in the camera? I can’t figure it out. Remember the tapes are straight from the camera! What is it I’m missing here? Specs below: Editing in PPro 2.0 Camera-- DVX100b View as 16:9 When captured in a 16:9 project they need to be rendered, then the size reduces. When captured in a 4:3 project they do not need to be rendered, but are still 16:9 format. The footage, even if I get this fixed is horrible, with bad noise and the worst color I have ever seen. I am going to try and save it, but not sure how. The guy who shot it is supposed to work for a local TV station. Thanks for any help you can give me. I know not what I do!!!!!!!!!!!!!! :) Mike |
Dynamic Link A Bit Static
I have been exporting uncompressed AVI's from PPro2 to use in AE7, exporting from AE7 to uncompressed AVI to bring back into the premiere timeline. What a pain. Now I should be able to use dynamic link. When I select 'Dynamic Link - New AE Comp' in Premiere, AE7 opens up and creates a new linked comp but I can't do anything with it, the little preview screen in the project pane is black. I have tried opening AE7 first so it dosen't have to be prompted by Premiere but same result. The Adobe help file is clear as mud. Surely it should be as simple as what I was doing? Go on then, what am I missing out? ;)
Make me sane again. |
Bump Bump!
It's possible that they were shot in a messy "4:3 letterbox" mode, in which it just shoots a 4:3 image, and puts a 16:9 matte over the image, as opposed to cropping and making an anamorphic 16:9 image. An old DV camera I owned had that feature, but I'm not sure how common it is.
The DVX100b has a letterbox mode, and a squeeze mode. I would guess the footage was shot in letterbox and should be edited in a 4x3 timeline. If you open squeeze mode footage in a 4x3 timeline everything will be vertically stretched. If you select a clip in your project window, it will tell you the pixel aspect ratio, 1.2 is widescreen, 0.9 is 4x3.
Hope this helps -Kevin |
How should the device control work exactly?
I was capturing footage yesterday and I found the device control a bit strange. The play and stop button and reverse and forward work fine. But the jog control and shuttle acted a bit strange in my eyes.
I switched from Final Cut Pro to Adobe Production Studio recently, and I bought the Adobe Classroom in a Book training book. There are 3 methods to capture footage: 1)press record and capture entire tape or a part of it 2)capture and log (and then batch capture) 3)capture using scene detection I like the 2nd method but it annoyed me tremendously. While in the monitors, the jog/shuttle controls work perfectly and are very responsive, in the capture panel it is completely the opposite. When I jog forward, I can slow-forward frame per frame untill a certain moment where it jumps back a few seconds in timecode. When I jog backwards, it immidiately makes strange jumps in timecode making it impossible to move to the desired frame. With the shuttle control, slow and fast forward work pretty much like in the monitors. However, shuttle backwards also works strangely. Fast-backwards works fine, but slow-backwards also makes these strange jumps in timecode. Is this typical Premiere behaviour is it dependent of the videocamera? Also, the slow-back and slow-forward buttons are grey. Is there a reason for this, or does it not work with certain types/brands of cameras?I am using a Canon XL-H1 (PAL model) and Cineform. I am also interested to learn which capture method everyone is using and why they have chosen for that particular capture method. |
HDV downconvert ppro2
If I downconvert the footage in camera Z1U, then edit it. When I recapture in HDV, will I have to edit the footage all over again?
I did this two or three times now because in some jobs I need to do a quick edit on location.
I use the downconvert of my FX1 (the same for Z1) and capture and edit in PPro2.0. I export it and show it to the audience. At the studio I create an Adobe HDV Project and import the DV project that I created on location. When you open a sequence created in the DV project you get a small video footage in the monitor window. What I do to ake right is make all the AVI's offline and recapture using batch capture without downconversion on the FX1. This really works...you only have to resize titles you made on the DV project. It's a tricky and time-consuming alternative to intermediate codecs like AspectHD...far from perfect...but it works for me and my specific needs. EDIT: to import an entire project you must import the .pproj file. it places all the project in a new bin |
The real question is this:
Does the batch capture of the HDV come out frame accurate? If it does, great. If not, then there is a lot of work to do to get it all to match again, isn't there? |
I think you may be a bit limited in your options using the XL-H1, as Premiere doesn't offer full support yet. Such as scene detect and print to tape in 24f.
I'm currently only working in SD. I always use scene detect, and just capture the whole tape. I just set it and forget it. But I'm usually capturing 5-6 hours of footage at a time, and I would go mad if I had to go through it manually. |
Thumbnail View issues
Hi Everyone,
I have a question regarding the Project Window. My issues is that when I import items into the Project Window and I change the display to Icon (or Thumbnail) View, the clips are not in alphabetical or numerical order. They are random and make no sense. My question is: how can I get the clips in order? A lot of time, I want to view things that were shot in sequence. And yes, I have changed the Project Window to List View instead of the Icon/Thumbnail View option and re-ordered the files so that they are in order when viewing them in the List View. When it is in the List view, everything is how I want it to be, but the moment I change it to the Icon/Thumbnail View, I revert back to the random and disordered Thumbnails. I hope I have explained myself well enough. If not, let me know. Thanks in advance! Jon PS I am using Windows XP with PP1.0 |
Incomplete VOB/MPG import
Hello. I have some .vob files from a clients handycam that he wants me to edit together. So I copy the VOB files to my HD, and rename them to filename01.mpg (as the case may be.)
I import them into Premiere Pro 2.0, and it seems to work. Except for the fact that only five out of the 25 minutes of footage is there. Why is this, and how do I make PPro import all of it? WMPlayer sees everything (i.e. the full length). Any help is appreciated, Mike |
Yup,
You are right Kevin. It was shot 4:3 .9 cropped. My few shots are 16:9 1.2. The people doing this can't get the people back together again, I'm the third camera person, in about 5 months. The first guy kept all of his footaqge and thier tapes and hard drive. He shot 9 hours of video for a 7 minute short and the actors were ready to give up. Then he quit and kept everything. What is the best way to incorporate my footage? Shrink it down to fit, or do some sort of render. The previous footage is so bad and the sound so messed up that I wish I could back out, but I promissed. If I enlarge their footage it will be very grainy and it is bad enough now. So best to modify mine, right? I have about 30 more seconds footage to shot for them. How do I do that, shoot 4:3 and crop in post? Thanks for the help guys, keep it coming. Mike |
In my case it really doesnt matter. And I didnt even check if it was frame accurate. The result in HDV seemed the same to me.
Again, in my case, quick edits, most of them in under 30 minutes, arent exactly frame acuracy dependable. It just serves to deliver the client a better looking sample of what was shown on location together with a final edit (usually a 6-8 hour session) in a full-HDV workflow. This presents me with a problem: the tape mechanism is getting used double time when i do this. One for the DV edit, another for the HDV re-capture. I intend to resolve this by buying a FireStore. It will save me time capturing on the field (and give me over an hour of extra editing time on location) and I would only need to run the tape once again for HDV capture...or never if I use AspectHD or similar. Just waiting for the bucks to try it. For now the mentioned workflow works for my specific needs. Paulo |
Help me with 24f
I just bought the XH A1 and I wanted to know if I record in SD 24f, should I still just select 24p in PPro 2.0??
Time code
Hi guys;
I'm using PPro. 2.0 And in the time line my time code display this numbers, 00:11:38:11511. I know that the last five digits are the frames, but I don't want the time code to display all those number, only fames. Anybody knows how to switch them back to frames only. Any help will be appreciated. It’s very annoying when you want to scroll frames but this way it takes too long to scroll thru the project. |
In SD, it works just like the DVX-100 or XL2. You choose 2:3 or 2:3:3:2 pull-down in the camera menu, and then make sure the PPro project is set for the correct pull-down.
To capture and edit native HDV F-Mode in PPro, you need the preset files that can be downloaded from the Adobe web site. Once you have those, just choose your preset and you're all set. |
James if you shoot SD 24f, then use the 24p preset in Premiere. I'm not familiar with the camera, but if you plan to edit in a 23.976 project, then I would shoot with the 2:3:3:2 advanced pulldown. I'm assuming the camera has this feature. I won't have one for another few weeks.
I'm wondering if it has something to do with the embedded chapter points. Is there a way to get Premiere to ignore this?
I suspect it's rather the poor handling of mpeg files all together. I am having all sorts of issues with a similar project where the client handed me a hard drive camcorder (JVC Everio). Depending on what you mean by "edit together" you have several options - I spent about two weeks now, on and off, on this project.
Bottom line is: Premiere, although can handle MPEG, it doesn't really like it (I suspect it's actually not Premiere but Windows, but I have no means to confirm that). If you have to do editing on the footage, you are better off decompressing the footage with Movie Maker - I know, it's a primitive app, but it does the job. It will take some time, but you can also add the clips together if you have to. Just export as DV-AVI from Movie Maker and import that into PPRO. If you don't need to do any editing on the footage, and your final product is a DVD, you can use Encore - in my case it is unpractical since I have close to 200 clips, most of them very short (10-30 seconds). I tried several pieces of software to "stitch" the clips together without any other editing, but could not find a working piece of software. Good luck and come back with your results, lets put together a workflow to help everyone else on this forum! |
So what you are saying is that scene detect does not work with 25F footage? As far as I could judge, the icon was active with 25F footage. I will have to test this... I am using the Cineform for Premiere codec.
