Uninstall or not to Uninstall that is the question
I have an edit machine that has a SSD as the C drive. I need to get a larger SSD because mine is full. I was thinking about cloning it to a larger drive. Here is the question will changing the drive make Adobe soft ware stop working? Should I remove it then reload it after the move or will just shutting it off temporarily work.
Re: Uninstall or not to Uninstall that is the question
1 Attachment(s)
Instead of getting a new SSD, have you considered CLEANING UP ?
There is no logical reason to have more than 30 - 35 GB on your boot disk, plus the page-file. See Tweakers Page - Tuning Guide |
Cloning (or cleaning) saves an Adobe activation life - you used to have twenty I recall in the good old days of perpetual licences. |
Thanks to both of you I will try cleaning up my drive.
