Problem with Camtasia TechSmith codecs and Premiere CS6
Hello I have to use Camtasia but for some reason the videos exported there when the are inside PP CS6, I can't see the video only hear it, when I go to the export settings windows, inside there I can see the video but not while editing, any tip on how to solve this?
Thanks in advance. |
Re: Problem with Camtasia TechSmith codecs and Premiere CS6
You need the 64 bit version of the Techsmith codec.
The installer is here: https://support.techsmith.com/entrie...bit-TSCC-codec |
Thanks for answering...I already was using the 64 bit version. What I found now its more strange. This project is taken from a station and then to a laptop with the same versions and for some reason it does not work in the laptop, well the weird thing is that when I turn CUDA off then it works! ????...the station where was originally created has CUDA turn on!, so really I don't know what's going on here.
Not sure that enabling CUDA for Adobe on a station using Camtasia to capture makes a difference...maybe I'm misunderstanding...
Whenever I screen capture from camtasia, the weirdness and inconsistency of the techsmith codec forces me to rip it to a JPEG/PNG/whatever sequence and edit that. Much more consistent.
This is the situation:
- Workstation: screencast in avi using Camtasia with its techsmith codecs, edition with Premiere with CUDA. - Laptop: opening the workstationīs project with same version of Camtasia, codecs and Premiere...NO video playback in timeline...when CUDA is turn off, magically video playback returns. It make no sense and I donīt understand what goes behind for CUDA being an issue...or not? |
Premiere cannot handle Techsmith codec.
Capture with the Lagarith codec then you will be fine. http://lags.leetcode.net/codec.html |
...Premiere Pro does not handle the .camrec file.
On Windows you use the Camtasia Studio application to rewrap the file as an AVI...but the compression remains TSCC... I don't know if you can operate the same way with their EnSharpen QT codec...but the Windows workflow works well. |
Hello again,
I can't use other stuff other than Camtasia, because that's what they use at work and there it works. |
