Export ProRes 422(HQ) w PCM Audio?
1 Attachment(s)
Hi all, I'm running Premiere Pro CS 6 at work (v6.0.2) in addition to Media Encoder, but I can't seem to export a ProRes file with the audio encoded as PCM.
PCM audio with the ProRes file is one of the requirements for a video ad I'm submitting to a vendor I'm working with, hence the need to do it this way. But, if you look at the attachment, I don't see this available. I do have FCP if I need to export through that or Compressor as a workaround, but I'd like to know if it can be done within Premiere's or Media Encoder's settings/presets. Best, James |
Re: Export ProRes 422(HQ) w PCM Audio?
excuse me if I am wrong.
you can make a separate .wav file as an alternate / workaround. thanks. |
Choose the "Uncompressed" option
James -
Did you ever find a solution to this? ========= Rajiv - How can you make a .WAV file if it's not it the drop down menu selection? |
