What is this Now, Grrrrrrrr
4 Attachment(s)
Any know that this is in my export, its not on the Time Line ?
Re: What is this Now, Grrrrrrrr
Never seen this. Is it there when exporting to another format?
I have no idea on whats going on, i removed the preferences , then restarted the Mac, and tried it again, same settings nut its not doing it this time, so i do not know if its a bug or something else. very frustrating.
Do these artifacts show up in the final rendered file, or is it only on video overlay in AME? If only the latter, I'd guess it is a GPU driver issue.
Hi yes it turns up in the finished export as well.
My first guess is that it would be some sort of codec error. Is there some other workflow that you can try for producing the DVD?
Andrew |
Ok, tried a few different settings, seem to have gone. ? Strange. !!
LOL. Just hurry up and get the DVD out while the going is good! :-P
Andrew |
Sometimes this effect happens in certain codecs when you have highlights higher than 255 or blacks lower than 0. Check your color correction at the offending places or put a broadcast safe filter on top of everything.
