-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Problem on Sharpen Premiere Cs6 (https://www.dvinfo.net/forum/adobe-creative-suite/509394-problem-sharpen-premiere-cs6.html)
Jordi Luque July 18th, 2012 06:13 AM
2 Attachment(s)
Hi All,
I've noticed a problem when applying sharp on premiere CS6 (mac OSX) to my 5Dmk3 footage. When I apply sharp a 'white' thin line appears around entire image...its really frustrating. Even If rendering/exporting the thin white line around is there!! ( I have tested with my macbook pro too, same results.
On after effects using sharpen, the issue is still there and it is very noticeable.
I have not find any info googleing, many people use sharp on Cs6 for 5dmk3 footage with not reporting issues ((
Any ideas?? Thank you so much!!
Roy Feldman July 20th, 2012 06:10 AM
Re: Problem on Sharpen Premiere Cs6
I white line means you are adding too much sharpening. The sharpening effect is made to bring out the contrast difference between objects, when set too high it will halo, I suggest a more moderate setting.
Ann Bens July 20th, 2012 12:04 PM
You should not get a thin line even when the effect is set to 100.
Is this with or without MPE hardware on.
Is your system up to date.
Premiere's latest update installed?
Peter Manojlovic July 20th, 2012 09:28 PM
Are you talking about the white line at the far edges of the frame capture?
It's as if the bevel effect was added.
It's not a white line, as much as it's perhaps the effect on the outside of the edges....Good catch, but i personally wouldn't worry about it.
It will never get seen on a regular TV...
