Dual mono tracks to Stereo submix
Hi guys,
I'm using PluralEyes, a program that syncs audio with video, and requires me to export a sequence into an XML. Unfortunately, XML takes all the stereo tracks I recorded with and makes them dual mono. In the timeline, I have now double the audio tracks, and each of them are mono. I would like to revert this. I found that I had to create a "stereo submix", but I have no idea how to take it from there. There's a lot I don't know about Premiere Pro, what do I do? http://i.imgur.com/SWKv8.png |
Re: Dual mono tracks to Stereo submix
Now, I don't know about PluralEyes and the XML stuff, and I don't know how PrPro sees your clips, but...
I shoot with an Canon XF100 and the video is a MXF format file. PrPro brings in the audio as two mono tracks. I can right click on the clip and select Modify -> Audio... and I can interpret the audio from two mono tracks to one L-R stereo track. Maybe you can do something similar? |
1. In Audio mixer pan your A1 track to -100 (left), and your A2 track to +100 (right)
2. At the bottom of each track in audio mixer there is a pull-down menu where this track is send after all the effects and sliders in mixer are applied. Choose your stereo submix track here. |
You can add effects to the whole submix track in the mixer, to the separate tracks in the mixer as well, and you can also add them to separate clips in the timeline by selecting clip and applying the effect. You can copy any of added effects to another clip by selecting the applied effect(s), right clicking and choosing copy, or pressing ctrl/cmd + C, and then simply choosing the destination clip(s) and pressing ctrl/cmd + V.
Unfortunately, you can't apply stereo effects to mono clips, but most of them are duplicates anyway, so it should be not much of a problem. |
I've decided to just take the original stereo files, and drag them to the timeline to create new audio tracks directly underneath the mono ones, then delete the mono ones. Didn't think of that one before. Thanks for the help anyways guys.
| All times are GMT -6. The time now is 11:19 PM. |
