-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Adobe Premier Pro (https://www.dvinfo.net/forum/adobe-creative-suite/504611-adobe-premier-pro.html)
Allan Birch January 21st, 2012 06:05 AM
Adobe Premier Pro
Hi
Which edition of Adobe Premier Pro works on Windows XP.?
Regards
Al
Harm Millaard January 21st, 2012 07:04 AM
Re: Adobe Premier Pro
Everything CS4 and before, but why you would want to do that escapes me.
John Wiley January 25th, 2012 06:20 AM
The current version of CS5.5 suite packages include CS4 versions of Premiere and After Effects, which allows you to work on Windows XP/32bit machines.
You can still install the CS5.5 versions later on if you upgrade your OS or get a new computer.
Panagiotis Raris January 25th, 2012 11:37 PM
32 or 64 bit?
Jay West January 27th, 2012 01:51 PM
I think the question is asking the OP if he is using a 32-bit or 64-bit version of XP? It is important because CS 5.x versions are not supported for XP64.
Randall Leong January 27th, 2012 09:05 PM
In fact, XP64 does not really support any version of Premiere Pro: That OS was not based on the "regular" Windows XP at all - but Windows Server 2003 instead. As such, it does not support a lot of multimedia features.
If on the other hand the OP has "regular" Windows XP, then yes, CS4 was the last version of Premiere Pro that supports Windows XP or any other 32-bit version of Windows (including Windows 7). Beginning with CS5, Windows Vista 64-bit or Windows 7 64-bit is required (although as mentioned above, copies of Premiere Pro CS4 and After Effects CS4 are included with all Premiere Pro CS5.x packages for those who are still currently stuck with a 32-bit OS or a system that's equipped with a CPU that lacks x86-64 support).
