Is there a way to set default bins for every new project?
Hi Guys,
Every time I start a new project in Premiere, I always keep it organised by creating 5-10 bins for different assets (Clips, Sequences, Audio, Titles) etc.... Rather than create these one by one every time, is there a way to set a default so it creates these every time in a new project? Is there a script that could run this? Hope you can help! Thanks, Neil |
Re: Is there a way to set default bins for every new project?
Create a project with your bin structure, without clips in it and save the project as a kind of template.
When you have a new project, either open this blank project and before you do anything else use Save As to create the new project with the bin structure, or import the 'template' project into the new project. |
I was wondering about this too. Thanks for the tip Harm!
I was searching for some script, plug-in or whatnot but that is an simple, great and logical solution!
Thanks a lot! |
