-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Encore wants to encode my .M2V files (https://www.dvinfo.net/forum/adobe-creative-suite/501255-encore-wants-encode-my-m2v-files.html)
Martin Kolditz October 3rd, 2011 03:33 PM
Hi there...
Before I had to do a clean install on my system, I was able to export an M2V from Premiere to Encore without Encore having to transcode after import. We'll use the following specs as an example:
NTSC 1440x1080i
29.97 fps
Quality: 5
Field: Upper
Bitrate: CBR/20
GOP: 2/8
Now, after the clean install, Encore is wanting to transcode the M2V files, no matter what settings I use.
Any ideas?
Thanks - Martin
Ann Bens October 3rd, 2011 03:43 PM
Re: Encore wants to encode my .M2V files
Set vbr to 1 pass on export see if that helps.
Martin Kolditz October 3rd, 2011 03:50 PM
Hi Ann
I appreciate your help, however that does not work. I'm at a loss! :(
Martin
Battle Vaughan October 3rd, 2011 09:23 PM
Any possiblity that your clean install removed a codec that you might have had previously?
Martin Kolditz October 3rd, 2011 09:32 PM
It wasn't a codec that was missing. About an hour ago I started fiddling with the Encore transcode presets. I'm not sure what I did, but now though it still says it needs to encode, when I build the DVD/image, it doesn't actually encode. Whereas before, I would have to wait for the M2V to encode. Not sure what I did but it's working for now! Thanks for the suggestions.
Bart Walczak October 4th, 2011 02:55 AM
DVD allows up to 9 MBps for a file, both audio and video. 20 Mbps is too much, and this is the reason.
Wesley Cardone October 4th, 2011 11:06 AM
I bet you a buck that you have your project preference set for Blu-ray. Flip it to DVD.
Martin Kolditz October 4th, 2011 11:43 AM
Hi there. I am building Blu-Rays. Made sure the project settings are Blu-Ray, and that format/output reflect that. Thanks for the input.
Ann Bens October 4th, 2011 12:29 PM
Try H.264 BluRay and is by the way a better codec.
And do not use Match Sequence Settings or Use Preview Files.
Alan Craven October 4th, 2011 12:59 PM
Encore has an unfortunate habit of wanting to re-encode Blu-ray compatible .m2v files. As Ann says, use .264 files instead.
Martin Kolditz October 4th, 2011 01:00 PM
Thanks guys, I'll try that! It will be worth a try just because of the quality issue. Cheers.
