Raid 0 ?
I have i7 machine with 8gb ram.
Tomorrow I will be getting the GTX 570 and and additional 8 GB. I was thinking of adding a 4T raid 0 to the computer but was not sure if it will make much of a different. I am currently using Sony Vegas and I am not sure what to expect from CS5 as far as hardware. |
Re: Raid 0 ?
What kind of source footage are you working with?
What's your workflow? |
Re: Raid 0 ?
Before you can decide if RAID0 would be helpful you need to determine exactly where your bottlenecks are.
If you are working with a compressed format such as MPEG or H.264 a RAID0 setup has no real value. If you are working with uncompressed video then its an absolute requirement (unless you go to a proxy workflow). Your average desktop hard drive can easily serve several streams of MPEG or H.264 without choking. Windows has a performance monitor that will help you determine where your bottlenecks are located. Unless you are using very high bitrate video your drives won't be the bottleneck. |
Re: Raid 0 ?
Thank you for taking the time.
Here is a link from Adobe TV that talks about raid and SSD Maximizing CS5.5 Performance With Intel Xeon Processors - Maximizing Performance with Intel Solid State Drives | Adobe TV |
Re: Raid 0 ?
Hey Dror...
You'll find that most people use SSD's for their OS system at the current time.. When things improve, you might see a shift away from hard disks. But there's no mass migration yet. But for the most part, people requiring Raid 0 are still using hard drives. |
