-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Rendering time in Premiere Pro CS 5 doubled? (https://www.dvinfo.net/forum/adobe-creative-suite/496627-rendering-time-premiere-pro-cs-5-doubled.html)
Radomir Charapich May 31st, 2011 12:17 PM
I have Production suite CS5 and I am working on video 2hr long. When I installed a program, it use to render in Adobe Media Encoder in real or less then real time, now is 2-3 longer!?
I have Dell Studio 8200 with four core i7 CPU 2.93 Ghz with 8 Gb of memory (6.5. dedicated to Premiere, Windows 7 home premium edition. Nvidida Geoforce GTX 260 graphic card. The resource Monitor shows a 100 % CPU usage during rendering in AME and "bigest" user is PProHeadless.exe with arround 60% and AME is in second place with30-40%.
Any sugestions how to speed up process again?
Peter Manojlovic May 31st, 2011 09:49 PM
Re: Rendering time in Premiere Pro CS 5 doubled?
"When I installed a program, it use to render in Adobe Media Encoder in real or less then real time, now is 2-3 longer!?"
What software was installed prior to slowdown?
Are you hitting the return button for rendering on the PPro timeline, or is this a render out of AME, without any pre rendering from PPro?
If you render via Premiere Pro, and export via AME, make sure the "Use preview files" option is checked upon export.
Also, try going to the preferences and using this setting....
Buba Kastorski June 1st, 2011 09:04 AM
Uninstall CS5 and install latest Vegas Pro :)
no, I am serious, I was thinking go Adobe, cuz i like image control options in PP, and I got tired of constant Vegas crashes caused by DSLR footage ( that was before 10d), so I got a very nice PC - i7 980, 24Gb, 2 X Revo SSD RAID0, Quadro FX 4800, editing with PP is pretty fast on this box, (Vegas is still much faster) but when i wanted to render 1Hr 20 min project with some heavy color correction it took 10,5 hrs, Vegas Pro renders roughly the same projects, on the same PC, to the same format in less than 2 Hrs;
I think I'm done with PP, but FCP X is coming very soon :)
Radomir Charapich June 2nd, 2011 06:49 AM
Thanks Peter and Buba, I will try your suggestions. Buba, I will stick with PPro for now, I have old (ver 6) Vegas, but it was a bundle with something else, I should buy full version.
Radomir Charapich June 2nd, 2011 07:13 AM
Sorry Peter I did not answer your question: I am rendering everything in PPro before AME, on the way that you described. I made changes as you suggested, I will keep you updated, I just finish 3 hours project ( some concert) in Toronto, after rendering I will post a results. Thanks again
Greg Gerber June 2nd, 2011 08:09 PM
Hard Drives too full or using Encore w/o the Premiere Pro CS 5 dynamic linked project open.
Radomir Charapich June 5th, 2011 10:01 AM
Greg, Hard Drive is not even 1/4 full, second part I am not sure what should be. After I changed settings as Peter suggested, rendering is much faster.
Other problem that I have is PPro is taking too much time to load a project. Project is massive, close to 100 Gb of media. I captured media to my external drive ( USB 3.0 connection), but when I open a project, PPro asking me where is media?! Strange!
Peter Manojlovic June 6th, 2011 02:52 PM
Hey Radomir....
Do you have "enable mercury playback" option under the "General" tab of your project settings checked?
Just a shot in the dark here...
Try right clicking over PPro icon, and Run as administrator...
If that doesn't work, i'd definately try uninstalling, and reinstalling both Windows and CS5.5.
Don't forget, there's a proper way to uninstall CS products. You need to deactivate first.
Also, sometimes Windows updates have been known to effect performance..
Radomir Charapich June 6th, 2011 07:36 PM
Txs Peter, i found that I have lock on my user name on PC ( I am trying to find out what is it?!). Bridge is finding my projects in pat : local disc/user/my name/my documents/adobe/premiere pro/5.0 and in the same time I can't see it from explorer, Weird? I don't know why Windows is setting lock on my user name, I tried to change this but did not succeed. It seems that I have two sets of my documents and one that I described is not visible! Strange.
Peter Manojlovic June 6th, 2011 09:56 PM
1 Attachment(s)
Do you have the settings like this?
Go to explorer, tools, Folder options, and use these settings....
Radomir Charapich June 6th, 2011 10:09 PM
It worked! Thanks Peter!
