-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Quality of DVD encoding !? (Premiere/encore) (https://www.dvinfo.net/forum/adobe-creative-suite/476449-quality-dvd-encoding-premiere-encore.html)
Mat Thompson April 8th, 2010 08:18 AM
Hi guys
Just wondering something. I'm writing a 13 minute DVD from premiere pro4.
What settings will achieve the best quality possible !?
Cheers
Mat
Noa Put April 8th, 2010 10:36 AM
There is none according to my experience, premiere does a crappy job transcoding to dvd specs, I always export a 1080p out with as less compression as possible (which by the way has a good image quality) and then use Tmpgenc to transcode that file to dvd. Have been doing frame by frame comparisons of both tmpgenc and premiere transcodes to dvd and you clearly see the difference.
Mat Thompson April 8th, 2010 12:49 PM
Thanks for your suggestion. I'm just wondering why an expensive piece of software like PPro/Encore shouldn't make a good job of this?
What uncompressed format do you usually output to intially !?
Mat
Noa Put April 8th, 2010 01:03 PM
Encore does a little better then premiere but still not up to the same level as tmpgenc. Why they can't do better is a very good question, eventhough most their other output formats are very good, transcoding down to dvd isn't on of them.
I usually film in Canon's 25f format and then I output to a 1440x1080 progressive file with a constant bitrate of 25mbs.
John Stakes April 8th, 2010 01:11 PM
I thought DVDs tapped out around 10Mbps? Or do you change it when outputting from tmpgenc?
Mat Thompson April 8th, 2010 01:26 PM
Ok then. I'm giving your process a go.
Max bitrate in TMPGEnc seems to be set at 8000. kbit/s
If I click on expert I can pick various options. What is the best choice - A constant bitrate or theres a setting that says constant quality !?
Mat
Ann Bens April 8th, 2010 04:33 PM
You might want to have a look at this.
Bellune Digital Video Services - Tutorials - Adobe Premiere Pro - HD to SD Using Premiere Pro CS4
David Chilson April 8th, 2010 08:15 PM
Very good tutorial!
Mat Thompson April 9th, 2010 02:48 AM
Great I will take a look at that.
I'm a little confused with the 'wide mode settings' !
Letterbox
Pan/Scan
Letterbox - Pan/Scan
I read up on what they are but can anyone shed some basic light on the application of these settings !?
Alan Craven April 9th, 2010 04:25 AM
The method offered on Anton's Video web site using VirtualDub gives very good results. His tutorial is for use with Edius, but I have written a modified tutorial for use with Premiere CS4, and using Procoder to get the higher quality DVD file.
Ann Bens April 9th, 2010 11:23 AM
I used to use Dan Isaacs' method. But changed Avisynth and the HCE encoder to TMPGenc (just out of lazyness). They gave exactly the same results. For the avi file i use Neoscene.
There is not difference in encoding quality between Premiere and Encore. The both use the same Mainconcept codec.
And leave it interlaced, you do not want to throw away half your vertical resolution.
Sareesh Sudhakaran April 10th, 2010 10:40 PM
use the best settings if you want to playback only on computers. If you want it to play back on older DVD players, then I recommend keep it around 6500kbps. Also, don't use VBR. Use CBR in your case since you have a lot of space to play with. It should be fine.
If you're making a data disc you can export full 1080 but DVD players won't read it. DVD is Standard definition.
Ann Bens April 14th, 2010 12:55 PM
When comparing CBR and VBR files of the same content and file size, you can make the following generalizations: A CBR file may play back more reliably over a wider range of systems, because a fixed data rate is less demanding on a media player and computer processor. However, a VBR file tends to have a higher image quality, because VBR tailors the amount of compression to the image content.
Rob Lagerstrom April 20th, 2010 05:57 AM
Wow! Best HD to SD tut ever
Originally Posted by Ann Bens (Post 1511809)
After months of frustration, ignorance and confusin, finally somone comes out with an esy to understand and comprehenive tutorial to obtain the best DVD from 1080i60, 1080p30 and 720p60. He also gives good exlanations of when to shot eachof the formats.
I am a little concerned about his recommendation to use VBR @ 8mbs. I have read that to be most compatible with most DVD players the settings should be CBR@ <8mbs.
Ann Bens April 20th, 2010 12:48 PM
For compatibility sake you could lower the burn speed.
Rob Lagerstrom April 21st, 2010 05:55 AM
lower burn speed reply
Ann:
Yes, I burn a 16x disc at 12x. I also use Taiyo Yuden discs. I have never had a complaint from a client, yet.
I am under the impression that it is the DVD players themselves that sometimes cannot read high mps discs. Though I do agree with you that most errors come from defective discs and/or max burn speeds.
Rob
Trond Saetre April 21st, 2010 09:40 AM
Hi Mat,
I'm using Premiere/Encore CS3, but I can send you my settings later tonight if you are interested.
Not sure if there are any encoding quality differences from CS3 to CS4.
If I remember correct, I have the average bitrate around 8,6mbps and max just above 9.
(VBR 2 pass encoding)
Never reduced the burning speed, always used max possible. (I think it is 12 or 16x)
