Sync issues when moving cs2 proj to cs4.
I took an old cs2 project timeline that I wanted to burn in cs4 and the strangest thing happened.
Some, not all, of the cuts were out of sync. That is on the timeline, CS4 started a half second early on some of the project's cuts. For example I have a shot of my daughter kicking a soccer goal and raising her hands in cs2 that in cs4 starts with her raising her hands and then shows her running away. I'm losing a lot of goals here. Maybe CS4 does not like watching soccer goals. Any ideas how I might correct this or what's going on. |
What method did you use to import the footy? Copy and paste? Import sequence?
The simple solution is to just finish editing your CS2 projects, in CS2. Then move to CS4. JS |
| All times are GMT -6. The time now is 06:43 PM. |
