Best Practices for nesting sequences in and between projects in CS4 dvinfo wiki
OK - some reasonably serious PP NLE questions. I am a newbie to CS4, and want to learn and share what I have learned. I will ask questions, offer my own solutions, and ask for better ones.
2) Let's say I have a 60 second portion of Sequence#1 in one of my projects that I want to use in multiple sequences or projects. between sequences - solution #1 - create a new sequence Sequence#2, place sequence#1 in it, then trim. - place sequence#2 into sequence #3 (or any other sequences where I want that clip). ** fine enough. but if I change sequence #1, sequence#2 changes. - oops. - solution #2 - duplicate sequence#1 to sequence#4. create sequence#5 and place #4 in it, trim sequence#5, place sequence#5 in any sequence I want, etc. ** this keeps the current edit of sequence #1 intact, even if I later re-edit sequence#1. This seems a bit messy (lots of sequences). Is there a more beautiful method? - solution#3 - export sequence #1, or Sequence #to after effects composition, then import into any project I want. **Are there any disadvantages to using AE to edit all my fancy animated transitions, then use PP to put them all together? 2) How do I bring sequences from one project into sequences for another project? Not the whole project, just a sequence from a project? - solution#1 - Replace it with an AE composition, then import into any project I want. Do further editing of the clip in AE, with different variations I can import into various projects... |
DUH - import the PP project, and in CS4, choose the individual sequence.
I will say, the more I use/learn PPcs4, the happier I get...
