Premiere 2.0 severally interlaced...
I shoot with a Sony FX1 in HDV mode. I then downconvert from the camera (using squeeze setting) through the firewire into the computer. I edit a SD Widescreen project and the footage looks severally interlaced. When I apply effects it becomes even worse. If I preview the original footage on my HDTV everything looks great.
Is there a setting I'm not choosing or is this a cause of the downcoverting from the camera? any help is appreciated. |
is there no one else out there having this same problem....???
when i edit in avid (my day job) using the same process I have yet to come across the interlacing problems that i encounter while using premiere. any help would be appreciated. |
