-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   SD 25f footage to edit with PP2 (https://www.dvinfo.net/forum/adobe-creative-suite/124112-sd-25f-footage-edit-pp2.html)
Ger Griffin June 19th, 2008 12:14 PM
I have SD footage recorded in frame mode (25f) with my A1.
I have pp2.
Should I set up a regular SD Widescreen project to edit this?
Any pitfalls I need to be aware of?
Ger.
Jiri Fiala June 19th, 2008 03:52 PM
No. When creating a new project, click a "Custom settings" tab and select "progressive" under "Fields". Otherwise you will run into interlace problems.
Feel free to create a preset for this settings so you won`t forget to set progressive fields on new projects (I know I do).
Ger Griffin June 19th, 2008 04:24 PM
Thankyou Jiri,
I just love this frame mode look.
I shot 50i for quite a while, playing it safe.
Im just wondering, and you seem like the man to ask,
are there any slowmo speeds that work reasonably well with this footage?
50% perhaps?
Jiri Fiala June 19th, 2008 04:59 PM
I don`t know... I use JVC ProHD camcorder which gives me real 25p (or 24p). But 50 per cent should look reasonably well. If you have After Effects, try to slow down your footage using Pixel Motion estimation method of frame blending.
Ger Griffin June 19th, 2008 05:56 PM
I just realised Ive already capture a lot of the footage into an SD project with fields set to lower.
Do I need to re-capture it or would that matter?
Jiri Fiala June 19th, 2008 11:51 PM
I think that it only concerns renders and previews so you don`t need to recapture... But am not sure about this.
Ger Griffin June 20th, 2008 07:17 AM
Thanks again I'll figure it out.
Jiri Fiala June 20th, 2008 07:30 AM
You`re welcome! And please post your findings.
