-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   How do I move tracks like layers? (https://www.dvinfo.net/forum/adobe-creative-suite/123506-how-do-i-move-tracks-like-layers.html)
Elijah Lynn June 11th, 2008 09:33 AM
How do I move a track up or down in my timeline?
and
How do I insert a new track in between existing tracks?
Thanks so much
Jiri Fiala June 12th, 2008 12:54 PM
Hi, you can`t. But you can select all clips on a track by A shortcut, and that selects all clips right from your cursor. Then move it to a track of your choice.
Elijah Lynn June 12th, 2008 02:19 PM
Is this a shortcut I have to make myself? This seems odd that premiere doesn't make this easy to do. So I cannot insert a new track in the middle of other tracks either? argh
Thanks for your reply
Andrew Hoag June 12th, 2008 03:37 PM
If your talking video tracks, it's pretty easy.
Say you have 2 video tracks, labeled from bottom to top 1 and 2. Just create a third video track (if you don't know how to do this, just highlight the Timeline and choose Sequence > Add tracks, then add video/audio tracks as needed).
Then, if you want to insert a video track between aforementioned tracks 1 and 2, then highlight everything in track 2, and drag it above to the newly made track 3. Then insert whatever new video segments you want in between the two.
To select all the video of one track, use the Track Select tool. It's a cursor with a marquee box around it, in your tools panel.
Elijah Lynn June 12th, 2008 07:00 PM
Thanks for answering.
Thats how I have been doing it although the track select tool is new to me. I wonder why adobe makes it so difficult. Seems like there are a few things about Adobe Premiere Pro that are just plain clumsy, like this.
Thanks again. I thought i was doing it the hard way and there was a much faster way!
Bart Walczak June 16th, 2008 01:46 AM
Well, PPro is not necessarily a composing software like After Effects :)
