-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Premiere CS3 thinks videos are offline and cant edit (https://www.dvinfo.net/forum/adobe-creative-suite/123485-premiere-cs3-thinks-videos-offline-cant-edit.html)
Jose Milan June 11th, 2008 03:01 AM
Hi,
I have a problem in Adobe Premier CS3 I haven't been able to solve at the moment. I would like to know if anyone has crashed against the same issue.
A partner has edited a video on his computer and once done I tried to open his project in mine. When the project is opened the source video window seems to be fine but the program video window shows the video offline. The timeline shows the different video parts with the correct frames; however, I am unable to edit since the program video window shows "media offline" and doesn't refresh and it doesn't show any of the videos.
Any idea on how to solve this?
Thanks in advance.
Harm Millaard June 11th, 2008 03:43 AM
Just make sure that your drives have the same letters and the same directory structure as on the other machine.
Jose Milan June 11th, 2008 05:06 AM
Hello,
We take care of that, we edit using external hard drives and when we open a project Premiere ask us where are all the files to relink them, we do this all the time with no problems (we have a name and ubication protocol to put all the stuff in the same places) and this is the first time, we can see the clips all over premiere (previews, source monitor, timeline), except for the program monitor and we cant edit, I exported to see if it exported right, but no luck the video came as "media offline", so of course we cant edit. We also tried to make a new project and import the whole old project into it, but the same happend.
There must be a way to solve this, right???
Greg Laves April 27th, 2009 05:09 PM
My PP CS3 just had the same problem. A search turned up this old thread. I had been editing for while, so I thought I would just shut down CS3 and reboot the computer. All the media is on an internal 1 TB drive. When I re-opened the project, the program monitor showed "media off-line". But all of the media is viewable in the source monitor. I played around with the sequence and I discovered that I could right click on a clip and select "Speed/Duration" and then just click OK then the media would show up normally. So I did that for all 200+ clips in this 1 hour program. Everything seemed normal. I closed CS3 and re-opened it. "Media off-line" again. Doooh. My next solution was to open a new sequence and copy everything from the original sequence to the new sequence. It was displaying "media off-line" in the original sequence when I copied it all. When I opened the new sequence, everything was there. I closed down CS3, again. When I opened it back up, the new sequence was fine the original was still fudged up. Anyone have any idea what I might have done so I can avoid doing it again?
