-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Wiere Error = [...\...\Scr\Audio\AsioHost.cpp-709] (https://www.dvinfo.net/forum/adobe-creative-suite/121899-wiere-error-scr-audio-asiohost-cpp-709-a.html)
Tyson Persall May 18th, 2008 06:46 PM
Premiere Pro has encounter an error.
I get this message when i try to play timeline. It Just started happening out of the blue. Restarted, problem remains.. Whats this one about?
I just booted into my other partition - windows XP and Vista both running Premiere CS3 both report this same problem when trying to play timeline. This must mean its some kind of hardware problem right? Could it have anything to do with the fact that the power went out in the house today - came back on and off several times - While i was in the middle of editing?
Problem persists on all projects new and old. Tried creating a new project. Import a video file - problem persists.
AsioHost.cpp-709
Tyson Persall May 18th, 2008 07:29 PM
Problem solved
OK,
I dont understand why - but this error occurs when you have an audio transition on two tracks back to back, and then you disable both audio tracks with that transition on it. It causes this error. For some reason once the error starts - it persists to all projects you open.
I had to delete the transition and restart computer and problem is solved. Plays now.
John Stakes September 30th, 2011 11:47 AM
Re: Wiere Error = [...\...\Scr\Audio\AsioHost.cpp-709]
THANK you for this info!
JS
