NTSC Timeline + HD 24P Clip + Effect = Resolution Drop
2 Attachment(s)
Hi folks. I believe I've discovered a bug in Premiere Pro CS3.
Last year, I created a series of recycling PSAs using 720p24 source material scaled down on a NTSC-DV timeline in PPro 1.5.1. Everything used to look great in that version. The client recently asked for some updates, so I opened the project in the latest version, CS3, and discovered that several of the clips had a terrible resolution drop. I did some testing today to find the root of the problem. I wanted to determine if perhaps it was Premiere or CineForm, but the problem occurs even with uncompressed HD material. Here is the recipe to create the problem:
The result is the vertical resolution drops by about half, as if Premiere is treating the progressive scan footage as interlaced and attempting to de-interlace it. Clips with no effects and Frame Blending turned off turn out okay. (Frame Blending is on by default in PPro CS3, so the resolution drop occurs immediately unless Frame Blending is turned off manually for each clip.) I should also mention some other strange quirks I encountered while analyzing the problem:
