-   Adobe Creative Suite (https://www.dvinfo.net/forum/adobe-creative-suite/)
-   -   Import problem in PP2 (https://www.dvinfo.net/forum/adobe-creative-suite/100044-import-problem-pp2.html)
Bill Hamell July 29th, 2007 05:28 PM
When I try to import numbered stills I cannot check the "numbered stills" option.
Any ideas?
Thank you,
Bill
Dearl Golden July 29th, 2007 07:58 PM
The filenames have to be sequentially numbered. If they are not, then you can rename (renumber) them and try again. Should work.
Steven Gotz July 29th, 2007 09:14 PM
If you are using two monitors, move the dialog box to the other monitor.
Bill Hamell July 30th, 2007 01:09 PM
Thank you both for your replies the file names are as such test0001.tga - test0075.tga and I am using a single monitor a laptop.
Bill
Steven Gotz July 30th, 2007 01:13 PM
You should be able to select the first still, and then the box should be selectable.
If you try to select them all you can not select the checkbox.
Bill Hamell July 30th, 2007 02:50 PM
Steven,
Thank you, that is what I was doing incorrectly I was selecting them all. Doh!
Bill
