3D Blu Ray
Hi all,
What is required to create a 3D Blu Ray disc..? If you have editied footage, what software can be used for Authoring?? Adobe Encore ?? Does it require a special Blu Ray Burner ?? 12X ?? Any advice or links greatly appreciated.. Thanks.. |
Maybe this can help? Blu-ray Disc Encoding Overview. By the makers of Sony Vegas.
So far as I know, this is the least expensive system to get you into authoring spec compliant BR3D.
NetBlender, Inc. |
Re: 3D Blu Ray
I'm using side by side for Panasonic TV, which is okay, but I would really like to go to compliant BR3D. |
Re: 3D Blu Ray
Blu-ray FAQ - Frequently Asked Questions states:
I find it rather insulting that the copy-protection is mandatory on all Blu-ray discs. It means they are telling you how to run your business. You pay them for protection or you are out of business. Something John Gotti spent the rest of his life in jail for. |
Re: 3D Blu Ray
Does it make sense to switch over to NVIDIA 3D for small scale projects? |
Re: 3D Blu Ray
So I output my (side-by-side) 3D files from FCP via Compressor out to my external LG blu-ray writer. The blu-ray disc was burned ok and I played it through a Panasonic BDT300 BR player onto both a Pannie VT 3DTV and an LG 950 with no problem.
Since it was a short clip I also burned it onto a DVD as AVCHD and that also worked fine. I haven't paid any fees to anybody in order to do this, so am I going to jail? |
Re: 3D Blu Ray
Re: 3D Blu Ray
The licensing fees for Blu-Ray are fairly high, and the cost of an MVC encoder is pretty high, too. if you're only looking at producing one or 2 titles in limited runs, then you would look for an authoring service that can make a package deal for you. Remember that DVD and CD authoring were very costly when they were new as well, but the prices on authoring those formats is now very cheap. If you're looking for something for home use, or just to pass around to a few friends & family, you can make a side by side disk that many TVs will recognize. |
Re: 3D Blu Ray
I'm looking to burn 3D blu rays on a mac. It's my understanding that you just burn a 1080p SbS file and the playback device decodes that into 3D. Is this correct? Anyone burn 3D Blu-ray's succesfully with Compressor? Any other workflows with a Mac that people are using?
My goal is limited runs for festivals and friends with blu-ray tvs. Thanks! |
Re: 3D Blu Ray
Re: 3D Blu Ray
Thanks Neil. I guess I'll go ahead and buy that burner today.
Re: 3D Blu Ray
It's pretty painless, but it doesn't give you much fancy control over the menus etc. You can put a 2D still in as a background image and you can have chapters etc but all the menus are 2D as well.
I haven't worked out how to make it automatically switch the TV to 3D when the movie plays either, that bit eludes me so I have to manually select 3D mode. That is a pain and so only really good for demo's I guess until I can figure out how to do it. Putting my Pannie TV into "auto" 3D doesn't do the trick either so I don't know what gives. If you work it out I'd really appreciate knowing about it :) Cheers Neil |
Re: 3D Blu Ray
Re: 3D Blu Ray
Okay, I'm starting to piece it together. So, there are two routes to burning 3D Blu-Rays
1.Burn a SbS, Over/Under, etc file to a blu-ray disc and have the playback device decode it. Your video looses half resolution. Author with Toast, Compressor, etc 2. Use Netblender (or some other software) to burn the disc using the BD3D standard and get 1080p, 3D menus, and other bells and whistles. |
