April 1st, 2010, 10:56 AM | #1 |
Warning!! Do NOT install the newest QuickTime...
...or update iTunes if you have it on your production computer.
If you do, all your MOV files will show up black on your Vegas timeline. The only fix is to roll back to QuickTime 7.6.2 which can be found at QuickTime 7.6 for Windows If you updated iTunes, you'll need to uninstall it and go back to version 8. BTW, it also breaks DVFilm Epic I (the new DSLR plugin for Vegas). I wish this were an April Fool's joke but it's not. |
April 1st, 2010, 11:21 AM | #2 |
I noticed the same behaviour. Took me a while to find the culprit.
Our Fire Films - a free film project. |
April 1st, 2010, 05:30 PM | #3 |
Thanks for the warning. But if you have an iPod which absolutely requires the newest iTunes just to even function, then you're out of luck. I have an iPod which requires version 9 of iTunes just to even function at all; it is not recognized at all in version 8.
Similarly, if you have an iPod and Windows 7, you're also out of luck. This is because version 8 is not compatible with Windows 7 - only version 9 is. |
April 13th, 2010, 07:40 AM | #4 |
i stumbled on this entry on Sony's website on this topic.
It includes a .dll fix. MPEG-4 audio is no longer functional which has a link to this file: http://www.sonycreativesoftware.com/...es/qt7plug.dll |
April 13th, 2010, 08:10 AM | #5 |
From the Pro 9.0d release notes:
* Corrected a problem that could cause black frames in MOV files after installing the QuickTime 7.6.6 update. BTW, installing QuickTime 7.6.4 (not too hard to find on the 'net) cured my problem and still let me use the newest version of iTunes :-) |
April 13th, 2010, 10:16 AM | #6 |
It only happens with a combination of certain versions of QuickTime and Vegas 9.0c.
April 13th, 2010, 02:29 PM | #7 |
it appears that the new Vegas 9d solves this problem
April 13th, 2010, 03:47 PM | #8 |
Contributor
Vegas 9.0d solves the Quicktime 7.6.6 problem for DVFilm Epic as well :)
April 14th, 2010, 09:41 AM | #9 |
Thanks for the heads up
I discovered the problem last night and wasted at least an hour on it. Thought I was going to have to go back to an old image and update everything from there this weekend.
I'm downloading v9.0d now. Thanks for letting us all know! Ken |
April 17th, 2010, 02:22 PM | #10 |
QT version compatibility update
I have just tested Quicktime v7.66 and it has the same problem with MOV files showing up black in Vegas v.9.0c.
However, v7.65.18.40 works! You can download it here: Download Freeware QuickTime Player 7.65 |
June 16th, 2010, 01:56 PM | #11 |
Latest QuickTime and Vegas - Now OK?
I've searched around on here.... but I'm still not sure about this. I'm installing Vegas 9E on a new PC right now and I just wanted to know if this QuickTime/Vegas problem is now resolved (with Vegas 9E).
I'll install an earlier QT version (linked in this thread) until I know more but would appreciate any info - thanks!
Andy K Wilkinson - https://www.shootingimage.co.uk Cambridge (UK) Corporate Video Production |
June 17th, 2010, 06:54 AM | #12 |
Sponsor: JET DV
Here's what the release notes for 9.0d says:
Edward Troxel [SCVU] JETDV Scripts/Scripting Tutorials/Excalibur/Montage Magic/Newsletters |
