Multifaceted frames within frame at DVinfo.net
Old August 17th, 2009, 07:57 PM   #1
Is there a way to create a postcard on the timeline with multiple frames within the frame, and each separate frame running it's own movie?
I've attached an example since I can't figure out how to pose this question.
Each of the small frames would have it's own footage.
-BT
Bill Thesken is offline   Reply With Quote
Old August 17th, 2009, 08:21 PM   #2
for this you need 5 timelines-place each clip on a timeline and use a combination of track motion and pan/crop to size and adjust positioning.
To accomplish the black border between each shot you'll need 1 more timeline and place a black generated media pulled to cover the lenght of the project but make sure it's the bottom TL as Vegas works from top down.
HTHs
Don
Old August 17th, 2009, 08:32 PM   #3
Thanks Don, I'll give it a try. -BT
Old August 18th, 2009, 08:07 AM   #4
Sponsor: JET DV
If you're using the Pro version of Vegas, there's even some scripts out there to help simplify the task.
Old August 18th, 2009, 11:18 AM   #5
You mean something where I just set up a template and add the footage?
Old August 18th, 2009, 11:31 AM   #6
Sponsor: JET DV
Typically, it's the other way around. You add the footage to the timeline and then the script will adjust the footage to fit.
To do it manually, just take a look at Track Motion. It's not hard at all to set up.
Old August 18th, 2009, 12:56 PM   #7
You want this, free and easy.
http://www.davitools.com/videowall/homevw.aspx
Paul.
Round 2
GH5,FZ2000
Old August 18th, 2009, 01:18 PM   #8
Whoa this great Paul, can't wait to try it out, thank you!
