Multi channel audio capture. at DVinfo.net
Old February 4th, 2009, 09:19 AM   #1
Good Morning,
Base Question: When I capture multi channel with my xl2, will Vegas do that for me?
I have looked through my reference text by douglas and can't find the answer yet.
If so is there any particular procedure necessary to follow?
I have used scenalyzer for this process in the past but sense it causes me driver problems with other software I was wanting to avoid using it.
thank you!
DATS ALL FOLKS
Dale W. Guthormsen
Old February 4th, 2009, 09:58 AM   #2
Sponsor: JET DV
If you record 4-channel audio, Vegas will not see channels 3 or 4. You will need to use Scenalyzer for that.
Old February 4th, 2009, 08:17 PM   #3
Edward,
I am curious, if I shoot hd, then capture in dv, then save the added audio files would they then link up properly with the hd files after I capture them? I don't think scynalyzer captures hd.
thanks for the information.
DATS ALL FOLKS
Dale W. Guthormsen
Old February 5th, 2009, 07:43 AM   #4
Sponsor: JET DV
You are correct that Scenalyzer will not capture HD. But what you mention should work fine. Capturing the audio in SD and then the video in HD seems a viable solution.
Old March 24th, 2009, 01:49 PM   #5
is there some thing other the scynalyzer i can use to capture multi channel audio? scynalyzer dosnt seems to install correctly on my computer
Canon XL2, 20X zoom and 3X wide-angle, , Sony Wireless UHFs UWP-C1 and UWP-C2 , Manfrotto 503 head on 351 tripod , Glidecam 4000 Pro w/Glidecam Smooth Shooter
Wajahat Abbasi is offline   Reply
