Quick Release Solution at DVinfo.net
Old October 2nd, 2010, 05:05 AM   #1
Hi,
i have a GlideCam 2000HD and a Manfrotto 701HDV Head. Can you tell me how can i install a system that allow me to switch from one to the other quickly? I´ve seen quick release systems but not shure of what i really need. Can i use the adapter from the Manfrotto head, and install a plate in the glidecam and use the adapter from the manfrotto head there?
Thanks in advance
PS: Sorry if i was not explicit, as my native language is not english.
David Ribeiro is offline   Reply With Quote
Old October 2nd, 2010, 01:03 PM   #2
Images: 18
Hi, David......................
As the 701HDV head uses the 501PL slide plate, you can attach one of these adapters:
Manfrotto Quick Release Adapter with Sliding Plate - Plate Adapters
to just about anything you want and simply move your camera with attached slide plate from one unit to another at the flick of a lever.
It can also be used to convert any non 501PL plate unit of any description to a 501PL system by simply being screwed to whatever plate is in use.
It is an exceedingly versatile little gizmo.
CS
Old October 4th, 2010, 03:10 AM   #3
that is perfect.
Thanks for the help!
David
