Steady stick from Tiffen at DVinfo.net
Go Back   DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
Old January 28th, 2007, 12:37 PM   #1
Anyone currently or had use these for their fx1/z1?? Please give feed backs. Considering one ...my wrist is starting to hurt...video carpal tunnel. Ido have a monopod but this seems very versitle and has a quick release.
http://dvcreators.net/steady-stick
Making Family Videos Not To Look Like Family Videos
Fred Foronda is offline   Reply With Quote
Old January 28th, 2007, 01:59 PM   #2
I have never used one on a fx1 or z1 but this stick was great for my gl2.
I actually like this thing for long static shots where mobility is key. One issue I have with it is that you cannot use it with larger cameras such as my hd100 because the screw that tightens the telescopic shaft does not do too well at securing the load so it will often drop. If that were fixed, it would work great with the hd100 and other heavy camcorders.
Ultimately, if your going to use this for mobile run & gun type of stuff then don't bother with this because you can't walk and shoot at the same time. The stick transfers the movement of your body to the camera = very annoying.
However, I still recommend it because it's really cheap and sometimes it comes in handy for long static shots. I first used mine in 2004 to videotape a kerry campaign speech and it was able to scale the crowd and my wrist wasn't dead at the end of the speech.
Jonathan
Jonathan Nelson is offline   Reply
  You are here: DV Info Net > The Tools of DV and HD Production > Support Your Local Camera > Shoulder & Handheld Supports
