First Matte Box at DVinfo.net
Open DV Discussion
Old March 28th, 2017, 05:57 AM   #1
First Matte Box
Hi All,
I'm looking for some advice on affordable first matte box. I've been looking at the Fotga DP500 Mark 3.
Although I can't find many reviews of it, it seems to have most of the features I'm looking for.
However from a youtube video it seems it might be a little big for my rig. I'm currently shooting on a Canon 70D, but looking to buy something that will grow with me as and when I upgrade to different cameras.
Any comments on this particular matte box?
Any suggestions for good alternatives?
I'm not sure whether to go for a matt box like this one with 4x4 filter trays or whether to go up to 4x5.65, as I understand I may run into vignetting on wide angle lenses.
Any help would be greatly appreciated.
Regards
James
James Buckett is offline   Reply With Quote
Old March 29th, 2017, 01:18 AM   #2
Re: First Matte Box
Hi there
I have used a larger matte box like the one you mention, (mine is a TLS Kestrel) on a 5D, but they are very large on a DSLR.
If you don't need to stack filters, a cheaper and lighter option is the new range of Zip boxes by Wooden Camera.
https://www.woodencamera.com/zip-box...m-p/231500.htm
These look pretty cool and won't add loads of weight to your rig.
cheers
Gareth
www.gwenllyn.com
Gareth Watkins is offline   Reply With Quote
Old March 29th, 2017, 04:23 AM   #3
Re: First Matte Box
Originally Posted by Gareth Watkins View Post
Hi there
Thanks for the suggestion Gareth, I'm sure your right it would dwarf my camera and would certainly like to get a slightly smaller one if similarly prices/featured. But I'd like to get a matte box with at least two trays one for ND filter and one for a polariser that can rotate 360 degrees ideally.
At the moment I'm using a variable ND via a step up ring screwed onto the lens and don't find it ideal.
I'd rather invest slowly in some quality glass that I can use on any lens I buy in the future and save the faffing (screwing filters on the end of each lens and having to change step up rings etc). So a matte box looks like the way to go.
Regards
James
Old March 29th, 2017, 07:52 AM   #4
Re: First Matte Box
Regards
James
As much as I loved and used a matte box on my Sony Z1, I simply found it too big and not very practical on a DSLR. I ended up preferring the Tiffen variable ND on my 5D3, I got one for each lens. Swapping out expensive 4x4 ND filters, with out getting fingerprints or risking dropping them was to me too much of a hassle, as well as needing three or four filters which aren't cheap. The variable I could just rotate it as light changed.
I did miss using my polarizer and grad's on some shoots...
ND's in particular are very important filters in video, but to be honest I stopped using the matte box with a DSLR and went with the variable screw on.
I do on occasions use it with the C100 when I want to use a grad or polarzer though.
Check out the Genustech.. they look good for the money
cheers
Gareth
www.gwenllyn.com
Old June 13th, 2017, 12:57 AM   #5
Re: First Matte Box
I have a Tilta that works OK for the little I use it.
Old June 14th, 2017, 07:02 AM   #6
Re: First Matte Box
I hate a big mattebox on a smaller rig - I'm happy with my cavision 3x3
Cheers - Paul M.
www.perbenyik.com
Old July 8th, 2017, 04:15 PM   #7
Re: First Matte Box
I just bought a Fotga DP3000 ; it just arrived today .
The matte box itself , despite its low price , is actually a very nice piece of kit , with much of it being made of metal and other pieces hard plastic , it all seems well engineered and durable , the French Flags fit nicely and are easily adjusted , both for tightness and positioning . There are two 100mmx100mm filter holders , one rotatable and the other just slides in and out .
As it comes , the box is designed to be mounted on a 15mm rail system . The way my camcorder is set up ( JVC GY-HD251 ) it mounts onto a standard Sony quick release plate ; if I were to mount a rail system onto the bottom of the camera I fear I'd lose the ability to mount/dismount from the plate , and if I put the rail system under the plate , I'd either have to remove the camera from the matte box if wishing to shoot handheld , or lose the ability to shoulder mount it ...
As it happens , both my ENG lenses have 82mm filter threads on the front , and both are internal focus , so I looked for a solution that would allow me to mount the box onto the front of the lens .
I remembered my Lee filter system that I used to use back in the days of medium format , and found up in the attic a filter holder and bellows type lens hood ( a bit too narrow for use with my camcorder ) and although I had a few mounting rings , there wasn't an 82mm one . I looked on eBay for an adaptor ring , and came across a Zomei starter kit , which was a filter holder plus an 82mm adaptor ring , for about £14 , so I ordered that too . Not so keen to start messing up my expensive Lee holder , I didn't feel so bad at drilling a few holes in the Zomei to make it do what I wanted .
It was a simple enough matter to remove the cowl surrounding the rear blanking ring off the matte box , and unbolt the 15mm rail mount flange . I then drilled holes in the Zomei filter holder to match the hole centres for the rear cowl and , at the same time removing one filter slot from the Zomei to make it shallower and mount the box that much closer to the lens , mounted it onto the back of the matte box using the countersunk screws which had come out of the cowl ; it all fitted together very nicely .
I did find that , while the Zomei holder would sit nicely onto the adaptor ring and support its own weight without any difficulty ( it is just an interference fit , a bit like a bigger version of the Cokin A series filters I used for my SLRs in years gone by , with the added weight of the matte box , the plastic springs weren't quite strong enough to keep the holder accurately in place . I remedied this by drilling another two holes in the filter holder just above where the adaptor ring sat , then screwed in a couple of pan head self tapping screws just so that when the holder , with matte box attached slides down onto the adaptor ring , the flanges of the two pan head screws just sit nicely on the top edge of the adaptor ring and support it just where it needs to be .
Having said the above , the matte box is quite light in construction , which is fortunate as I wouldn't want to hang too much weight on the front of an already quite long lens ( Canon YJ12x6.5 B4 ) . As it is so far , I have not done anything but unbolt parts off the matte box , all alterations have been to the cheap filter holder , and if I find a way of fitting a 15mm rail system to the bottom of my camcorder then I would do this and put the matte box back the way it was on arrival . I'd need to find some way of fitting a rail system between the base of the camcorder and its front foot , and spacing the rear foot down by the same amount so that the quick release plate could still be used , and keep the shoulder mount available .
I wanted the matte box primarily so that I could use ND , CP or graduated filters , and also to give me a little more control of shading where shooting towards the light could be a problem . If I don't always need the matte box then I won't complicate things by fitting it when the standard lens hood will do .
I should still have a Cokin P series CP somewhere , which I have yet to find , and seem to recall it is about the right size for this holder but not entirely certain , but I ordered an inexpensive set of 100mm x 100mm ND and graduated filters which should be here soon enough , I also ordered a 100mm x 150mm grey graduated filter which can slide vertically in the Zomei filter adaptor to find the right position to darken down a bright sky ( the matte box accepts square filters but there is no facility to slide them up/down to adjust where the transition takes place , although one holder does rotate , they are just either in or out ) .
I plan to also get a tobacco graduated filter and a blue one since I like the effects these ones can have ; again they won't be for use all the time , but they can be useful .
Derek Heeps is offline   Reply
