New PC
Please let me know how this will run Adobe CS5 Production Premium... Let me know if i need anything else!
Also, how should I configure my Hard disks? Psu- Antec TP-750 MoBo - Asus P6X58D-E Processor - Intel i7-950 3.06Ghz GPU - nVidia GTX 470 1280MB Mem - Corsair 12gb ddr3 1600mhz Controller Card-Koutech IO-PESI330 PCI Express x1 SATA III (6.0Gb/s) --- MoBo only has 2 Sata 3 ports OS drive - 640G WD Caviar Black Sata 3 7200rpm 64 mb Storage drives - 2 ea 1TB WD Caviar Black Sata 3 7200rpm 64 mb BR Burner - Lite-on IHB112 |
Kyle,
I would ditch the PCIe SATA III controller card altogether because no current mechanical hard disk could saturate even SATA II, let alone SATA III. In fact, the maximum sequential transfer speed of your "SATA III" Western Digital Blacks barely exceeds the maximum practical bandwidth of even SATA I. Plus, that particular SATA III controller card lacks the RAID 0/1 capability that the Marvell SATA III controller on the Asus motherboard has. That card is a perfect example of spending extra money and getting practically nothing in return, especially since the chipset used on that card is significantly more likely to corrupt data than the motherboard's native SATA II controller. Second, the Marvell SATA III controller (as built onto the Asus motherboard) does not work well in RAID (more specifically, it performs much slower than expected in RAID 0 mode). Therefore, my recommendation would be to connect the OS boot drive to the primary SATA III port and set the motherboard's BIOS to boot from that controller. Then, connect the two storage drives to the SATA II ports (the ones associated with the native Intel ICH10R). And set the two storage drives as separate disks. If you want to use the two disks in a RAID 0 array, I'd strongly recommend adding a fourth hard drive as your output drive (this can be of a relatively large capacity and/or a slower spindle speed and/or connected externally via USB 2.0 or 3.0). As for the 12GB of RAM, are you going to use three 4GB sticks? Or six 2GB sticks? You'll have a better chance of reaching the full rated (advertised) memory speed with three 4GB sticks even if they currently cost slightly more than six 2GB sticks of otherwise identical specs. |
Thanks for the input!
I planned to install 6 2 gig sticks on the mem... Also, you suggested to use the SATA 3 port for the system drive, there are 2 (ea) on board SATA 3 ports... is there a reason I should not use the second port for my AV drive and use one of the Sata 2 ports for the export drive... |
#4 | |
Running six 2GB sticks of memory at Intel's official maximum memory speed of DDR3-1066 is no problem. But running those same six sticks of memory at anything above DDR3-1333 speed is a crapshoot (meaning that it may or may not work). Any memory speed above 1066 is considered overclocked when it comes to the memory controller on lower-end (non-Extreme) LGA 1366 platforms. As for using the other SATA III port, you could (but I personally wouldn't recommend it, especially since the Intel SATA II controller is of higher quality than any current third-party controller chip). |
#5 |
Did you use the XMP setting in the bios? I read somewhere that it helped...the mem speed
#6 |
I did, and my system did not run stably (in fact, my system went into an endless loop of reboots until the BIOS detected a problem). In fact, both Intel and JEDEC officially limit XMP support to only two ranks of memory per channel (this means with most 2GB modules, only one stick of memory per channel is supported - a total of only three 2GB sticks). All of Corsair's 2GB sticks are double-ranked, meaning that one stick already eats up two ranks.
#7 | |
Is there not any increase in speed when you connect 2 disks or would I be better of just installing seperate disks? I use dslr and hdv footage currently but no uncompressed video. |
#8 |
Update...
I have the system up and running and after a bios update, I have the Corsair 12gb ddr3 running at 1600mhz with the XMP setting selected within the bios. I put the system drive on #1 Sata III port and the video storage drive on the #2. I have the other drive on one of the Sata II ports as The Controller Card-Koutech IO-PESI330 PCI Express x1 SATA III (6.0Gb/s) WAS INOP OUT OF THE BOX Adobe CS5 production premium will be here on the 27th :) $449.00 thanks to an educators discount! |
#9 |
I updated the bios and selected xmp in the bios as well and I"m getting 1600mhz speed on my memory now instead of 1066mhz before.
I have one 6g drive connected to the sata III controller and a second one should arrive today, I will check the drive speed first of one disk and then connect the second one in a raid 0 on the second sata III port with that marvell controller and check speed again to see what I have gained, I"m curious. :) I"ll let you know if there is any change. |
#10 |
Just tested with crystaldiskmark and checked the sequential read and write speeds, the western digital 1tb black drives reach a read and write speed of about 135mb, when I activated the marvel raid controller and link 2 equal WD 1tb black drives to a raid 0 I get 260mb read and 200mb write speed, not bad for a motherboard controller I think :)
#11 |
Just a bit of advice and a BIG WARNING about using WD drives in Raid - DO NOT USE them in Raid 0, 10, 5, 6, 3... because WD crippled them in order to force consumers to purchase their expensive RE3 & RE4 drives. Using the WD Caviar drives in Raid GREATLY increases the chance of all data being lost on those drives because they will 'time out' causing the Raid controller to think a drive has stopped working, and then the drive is reported as 'dead'. With Raid 0, this means all data is gone.
Furthermore, Randall can add more about his bad experience with WD Black drives and the problems he had while editing video. Plus, I vaguely recall that his PPBM5 scores got better after he switched to another brand of drives. The main problem with WD drives is their firmware and the disks constantly spinning down, which causes delays & issues when trying to scrub video. |
#12 |
Thx for the warning, I noticed yesterday that the drives were spinning down as you said after some time of being inactive and that caused at least 10 second delay before the program I wanted to start opened.
I think I will replace the wd black with another brand and use the black drives in a external usb 3.0 docking station to store backup files. |
#13 | |
I investigated further, and discovered that my performance increase came not from the new hard drive, but from updating CS5 to 5.0.2. 5.0.1 consistently performed slower than 5.0.2 in my system, especially in SD MPEG-2 encodes. Noa, Your particular 1TB WD Blacks (WD1002FAEX, not to be confused with the WD1001FALS that I had) are perfectly fine for use in RAID 0, RAID 1 or RAID 10 (which is just a combination of RAID 0 and RAID 1). Just don't use them in more complex RAID arrays than simple striping and/or mirroring. (In other words, you'll need to buy all RE-series drives only if you're going to use the drives in RAID 5, 6, 3 or any combination RAID involving one of those three levels; e.g. RAID 30.) |
#14 |
Randall,
Those WD drives still have the spin-down problem, which can cause them to be dropped from even a Raid 0 array, and that is not good. |
#15 | |
Every single consumer desktop drive from every single manufacturer now spins down constantly (at least recent models). And my initial warning now applies to all consumer-level desktop drives, not just WD. Which means that if you're going to use even RAID 0, you'll have to buy an astronomically expensive enterprise-grade hard drive from all of the manufacturers. |
