Scene file for HM 700 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old December 8th, 2009, 04:41 PM   #1
Dear forum,
I'm in a hurry with a complex project where I need to shoot with HD 251 an HM 700 together so I tried, using the DSC Camalign and the scopes in FCP, to match HM 700 matrix with Poalo Ciccone's True Color for GY HD 200 series.
The signal from the camera is captured in the computer via SDI with the Blacmagic HD extreme.
It is not 100% on the spot but, latitude and color wise, is far better than any camera's preset modes.
Here you are:
Detail – 4 (is not a must)
Black toe Normal
Knee Manual
Level 90
White clip 108
Gama standard
Master level Normal
R Level Normal
G level Normal
B Level Normal
Color Matrix Standard
Adjust
Mg&R Mg Level 4
Mg&R R Level 8
R&Yl R Level -3
R&Yl Y Level -3
Yl&G Yl Level -2
Yl&G G Level -15
Yl &G Mask Range 10
G&CY G Level 9
G&Cy Cy Level -13
Cy&B Cy Level -16
Cy&B B Level 2
B&Mg B Level Normal
B&Mg Mg level -8
R Rotation Normal
B Rotation Normal
G Rotation Normal
Color Gain Normal
Any comment or improvement is welcome.
All the best,
Eugen
Eugen Oprina is offline   Reply With Quote
Old December 9th, 2009, 12:28 AM   #2
Sorry,
I forgot to say that on the HM 700 I have a Fujinon 3,5X13 while on the 250 I have the Fujinon 5,5X16.
Eugen
Old December 24th, 2009, 02:09 AM   #3
The project is over.
They worked together ok, the HM 700 with GY 251. The HM with the above matrix seams to be a little green happy. Which may also happen because of the Fujinon 3,5X13.
Once again a realised that the matrix pasted in the forum message is incomplete so the Black level is -2.
All the best, good luck and Merry Christmas to everybody,
Eugen
Old January 29th, 2010, 07:04 AM   #4
Any new experiences with Scene and Picture Files?
Stephan Mussil is offline   Reply With Quote
Old March 8th, 2010, 08:23 AM   #5
Eugen,
Thanks for posting this information. I reset my 700 (I'm using the 14X canon Lens) and have been using the settings you mentioned. Seem to be working well. Colors are well saturated, and the blend seems to be good.
Anyone else used these settings as well? Any comments, recommendations on adjustments either way? Did you find the factory settings were better/worse?
I do see the green a bit, but it only shows during the golden hour...An I've been able to rid that with FCP color adjustments.
Let's hear your stories, pro/con...
Steve,
Bethlehem, Pa.
Steve J. Nordahl is offline   Reply With Quote
Old January 23rd, 2011, 12:16 PM   #6
WOW ! Its like a new camera ! Very accurate ! Thanks a ton. I am almost mad at myself as I saw this thread and saved the link about 5 months ago. Now I want to go back and shoot everything again !
One question though, if I were to use "Cinema vivid" with these new settings would that change this TOO much?
thanks !
Mw
Myles Williams is offline   Reply With Quote
Old January 24th, 2011, 02:32 AM   #7
Good to hear from you
on the forum Eugen, did you end up getting and working with the Nanoflash in the end? I'm still wondering if it'll give my 251 a bit more life. I've been spying the pmw500 and pdw800, but had a reality check when I priced the pdw800 with the best colour viewfinder and decent lens at $100k Aus roughly!!
Ouch !!
Adam Letch is offline   Reply With Quote
Old January 24th, 2011, 03:47 AM   #8
Myles,
It is not a good idea to use cinema vivid with my settings the colors will be inaccurate.
Adam,
251 and nanoflash work flawless, just get the last firmware and you have a new camera. The difference is significant.
Best,
Eugen
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
