Service menu on HM-700 - Page 2 at DVinfo.net
Go Back   DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
GY-HM8xx, HM7xx and HM6xx ProHD camcorders & decks.
Old May 9th, 2010, 12:27 PM   #16
you're right.. now it works! Thanks Eric!
Marcello Mazzilli is offline   Reply With Quote
Old May 9th, 2010, 03:06 PM   #17
with the new firmware, no problem, I use it before important shots and when I see dead pixel.
Eric Deyerler is offline   Reply With Quote
Old August 26th, 2010, 06:28 PM   #18
After many times I used to mark the defect pixel, the service-menu now never works!
I push display button, power on - hold focus-assist and menu - the only thing I can see is
Firmware-Upgrade ready and the Cam don't show me the advanced-menu.
Some month ago, it worked fine, but after one year work with the Cam, the trouble begins.
The solution is, I must push the buttons more slowly, then it works.
Old August 27th, 2010, 10:16 AM   #19
Hi Eric make sure your cam is setup to 720p and 60p otherwise the hidden menu will not work like in 50p
Mike
Mike Laisney is offline   Reply With Quote
Old August 29th, 2010, 11:43 PM   #20
Guide to fixing stuck pixels from JVC Technical Support
I recieved this handy, clear and useful PDF to explain how to fix defective pixels on our CCD's from JVC Pro Technical Support here in Australia. It's even got pictures! :)
Super handy resource that I wanted to share with you all.
File Type: pdf Pixel Compensation Procedure for GY-HM700.pdf (240.6 KB, 2168 views)
Daniel Marr is offline   Reply With Quote
Old August 30th, 2010, 04:50 AM   #21
you must push your buttons slowly, not at the same time
  You are here: DV Info Net > JVC ProHD & MPEG2 Camera Systems > JVC GY-HM 800 / 700 / 600 Series Camera Systems
