Run/Stop Cables from Wireless Follow Focus to nanoFlash at DVinfo.net
Convergent Design Odyssey
Old August 15th, 2011, 10:53 AM   #1
Question for the Convergent Design people,
Some background first. A few of us have been attempting to figure out a way to get a run/stop (start/stop) cable going to trigger a Sony F3 from a wireless device; either a Preston or a Bartech. Someone brought up the idea of developing a start/stop cable that could be used with either a Bartech or Preston that would trigger the nanoflash and simply not use the internal recorder on the Sony F3.
Has Convergent Design had a request yet to fashion start/stop cables for the aforementioned devices?
Some links that may be useful during the discussion on the matter...
http://bartechengineering.com/
fSTOP Wireless BarTech Digital Receiver (BDR) - PLC Electronic Solutions Ltd. Store
Preston Cinema Systems
-Andrew
Old August 15th, 2011, 03:11 PM   #2
Re: Run/Stop Cables from Wireless Follow Focus to nanoFlash
Dear Andrew,
The nanoFlash has a special Trigger Mode, "Record Level", which greatly simplifies the interface to a wrieless remote controller.
In this mode, as long as the contacts are closed, such as when a relay is used, or when a switch is closed, the nanoFlash will record.
I do not have the schematics for the controllers, but I believe that they can offer a solution.
Dan Keaton
Augusta Georgia
Old August 15th, 2011, 05:06 PM   #3
Thank you for the reply Dan.
I have attached a screencapture of the pin assignments on the HIROSE connector. Pin # 4 is the Record Start/Stop line. This would be combined with the ground?
Run/Stop Cables from Wireless Follow Focus to nanoFlash-remote_hirose_pin-diagram.png
Old August 15th, 2011, 05:15 PM   #4
Dear Andrew,
Yes, Pin 4 to Ground, either Pin 7 or Pin 8 will activate our Start/Stop circuit.
If you are in Trigger|Remote or Trigger Remote and Record, then
1. Press Once to Record
2. Press and Hold for 1 second or so, then Release to Stop Recording.
If you are in Trigger|Remote Level
1. Maintain Contact, Pin 4 to Pin 7 or 8 to Record
2. Open the circuit to stop recording.
Dan Keaton
Augusta Georgia
Old August 16th, 2011, 07:23 PM   #5
FYI Andrew, I believe both the Preston and Bartech can trigger momentary and continuous closure as different film cameras require one or the other, so this should not be a problem. A call to either should return info on which pins from their units will deliver which type of trigger.
Charles Papert
www.charlespapert.com
Charles Papert is offline   Reply
