XF100 test (lowlight) at DVinfo.net
Old November 13th, 2011, 04:35 AM   #1
XF100 test (a day and night, Prague), 1920x1080/50i, 50Mbps, shutter 1/50 (ones 1/25), gain from -3dB to +6dB, edited in avidMC with a little color correction, deinterlaced with fluid motion (it lost a small amount of the vertical resolution), export in ITU709 color levels 16-235. The sound and music are from the internal mic (live).
Pavel Sedlak is offline   Reply With Quote
Old November 13th, 2011, 08:34 AM   #2
Re: XF100 test (lowlight)
Very nice work by you and the XF100! What a great city to film.
Pat
Pat Reddy is offline   Reply With Quote
Old November 13th, 2011, 08:44 AM   #3
Thank you. I like the XF100 and she knows it .-) .
Old Town Square is a historic square in the Old Town quarter of Prague in the Czech Republic, it is a very nice place. http://en.wikipedia.org/wiki/Old_Tow...e_%28Prague%29
Old November 13th, 2011, 04:20 PM   #4
Hi Pavel,
Beautiful work and the music came out great, a real work of art. Thanks for sharing!
Regards,
Doug.
Doug Bailey is offline   Reply With Quote
Old November 13th, 2011, 04:51 PM   #5
Thank you very much. The musicians were a little cold, but still played very well. I like this kind of music, the clarinet has a great charm.
Old November 13th, 2011, 05:32 PM   #6
Hi Pavel,
I love your work, nice footage. Which preset did you use?
Tkanks of lot
David Le Nourry is offline   Reply With Quote
Old November 14th, 2011, 11:26 AM   #7
Hi David,
I used the settings cinegamma1 for daily shots, cinegamma1 for the first part of the evening and normal gamma (with the less sharpness setting) for the second part at lowlight.
Cinegamma1
- gamma Cine1
- black (master PED 0)
- black gamma (level 23, range 4, point 29)
- knee (automatic)
- SHP (level -1, HDF 0, COR 3, HVD 0, limit 0)
- NR (automatic)
- color matrix (select - Normal3, Gain 11, PH 0, R-G -8 but sometimes I used color corr. with red color)
- setup level (level 0, press off)
Normal gamma
- gamma normal3
- black (master PED -2, but better is -1 or 0)
- black gamma (all 0)
- sharpness (level -2, HDF 0, COR +12, HVD 0)
- NR automatic
- color matrix (select - Normal3, gain 20, PH 0, R-G -10 but better is -9)
My english is not very good, but perhaps it will suffice.
