c100 'baked in' profiles. - Page 2 at DVinfo.net
Old April 28th, 2013, 02:06 AM   #16
Re: c100 'baked in' profiles.
Are the profiles themselves locked/protected?
Nate Haustein PXW-FX9 / FCPX
www.flightcreativemedia.com
Nate Haustein is offline   Reply With Quote
Old April 28th, 2013, 08:15 AM   #17
Originally Posted by Nate Haustein View Post
EOSnutrl - I really like this one. It POPS! Matches up nicely with a DSLR in neutral picture profile. I can see myself using this quite a bit when a contrasty and saturated look is required.
Hi Nate,
I'm still looking for the picture profile will matching with DSLR (like 5DM3). Can you share EOSnutrl ?
Thanks.
Cuong Dinh Video
weddingfilmhd.com
Cuong Dinh is offline   Reply With Quote
Old April 28th, 2013, 10:05 AM   #18
From Brian C Weedr:
EOSnutrl: A profile for emulating the look of the Neutral setting on Canon DSLR’s. Proper WB is very important for getting the most similar look possible because the cameras react slightly differently to WB variation.
Gamma: EOS Std
Sharpness:
Level -10
Color Matrix:
Select EOS Std
Gain +41
Phase +16
R-G -32
R-B +4
G-R -21
G-B -10
B-R -3
B-G -15
Old April 28th, 2013, 10:17 AM   #19
Thank you very much.
Cuong Dinh Video
weddingfilmhd.com
Old April 29th, 2013, 02:34 AM   #20
I don't think they are. I wanted to try the EOSnutrl so I ended up putting in the settings manually for it - but initially wrote over the EOS preset I think! I reset the camera and added the EOSnutrl as a separate preset.
How can I be sure if they are locked or not?
Still no further forward with figuring out why I can't get the presets on from card.
Martin Trotter is offline   Reply With Quote
Old April 29th, 2013, 09:18 AM   #21
Locked profiles have a key next to the name. Perhaps you're trying to load C300 CP files into a C100? I'm not sure of the specifics, but I think they are formatted a bit differently.
Old April 29th, 2013, 03:12 PM   #22
Nate - I don't believe I was loading the presets onto the card properly.
James has sent me a link to Paul Joy's instructions which is something that I just couldn't seem to find anywhere - surprised it wasn't on Canon's instructions manual either.
For those who come across this thread and in the same position - here are instructions on how you load presets!
Canon C300 & C100 matching custom picture files | Paul Joy – Freelance Filmmaker
