May 7th, 2012, 06:30 PM | #1 |
Mitra 3D Microphone vs. ????
(The last Mitra thread I could find, was over a year old.)
The Mitra 3D Microphone and subsequent test and example videos have been quite impressive to me. The Mic: Mitra 3D Mic Pro : 3D Mic Pro One video: Mitra 3D Mic Pro on Vimeo However, I have yet to see it end up in any pro's bag. Is it just some flashy kit? When I asked a sound guy I know about it, he suggested that the same thing can be accomplished with two X Y microphones. "If you knew what you were doing" he said, "you could mount them in such a way that you record the same '3D' sound. As if it is all around you, mixing the two mics in stereo." So, I pose this question to the collective consciousness of DVInfo. If you had to record in "3D" stereo, how would you do it? Can you explain it in terms I would not have to go to collage to understand? :) Have you tried out the Mitra 3D Mic, and if so, what did you think? Thanks in advance. |
May 7th, 2012, 09:02 PM | #2 |
Re: Mitra 3D Microphone vs. ????
Lets start with the basic question: What exactly is "3D sound"?
How is "3D" different from "stereo" or "binaural"? If someone asked me to record in "3D", I would first insist that they define what that means. Absent that definition, the question is undefined and cannot be answered. What are you recording that you would need "3D"? How are you presenting/performing the recording that would yield a "3D" experience? That Mitra gadget appears to be simply a different design for a binaural microphone. One could make the argument that if you want a "real" binaural situation, you need something the size and shape of a head between the microphones to provide a more accurate simulation of what the ears are actually "hearing". And judging by the shape of the microphones, it suggests that they are trying for a binaural pattern. But the absence of the partially absorbing, egg-shape "separator" (simulating your head) would seem to restrict any true binaural performance. Furthermore what would you DO with a "3D" or binaural recording? "Tapers" go to rock concerts with microphones in their ears (or on their glasses) in an attempt to capture the atmosphere of the concert experience, and the recordings are only really experienced properly using headphones (or earbuds, etc.) Binaural is a very "niche" subset of stereo because it can't really be properly appreciated through traditional playback scenarios (i.e. through speakers). The kind of multi-channel sound you hear with a Hollywood movie is created synthetically during post-production. It is pretty rare for them to use anything more than 2-channel ("stereo") recording clips from which to construct very elaborate multi-channel surround audio tracks. Most of the elements are likely mono. I suspect those are some of the reasons you don't see those kinds of specialty gadgets in your average production audio recordist's kit. To be sure, you might find more conventional single-point stereo microphones in more than a few kits. Mainly for capturing clean "atmosphere" or sound-effect samples for use in the mix-down. But a pair of microphones is always more flexible to use than any single-point stereo microphone. |
May 7th, 2012, 10:53 PM | #3 |
I just went and watched the demo on Vimeo. It was significantly underwhelming. Comparing a stereo mic (of ANY kind) to a (mono) shotgun? Come on, what kind of scam are they trying to pull on us? I strongly suspect that the (no extra cost) built-in stereo mics on the camcorder would have produced just as pleasing sound of the babbling brook. The sound from the Mitra did NOT make me think I was there wading in the stream. It sounded surprisingly artificial to me.
I have heard MUCH MUCH better stereo from black vinyl disks 50 years ago. "3D"? Hardly. I didn't even hear very good stereo. The shots inside the prison (Alcatraz?) were particularly disappointing. I would bet you could get a better sense of stereo with the built-in mics on a H4n. I wasn't impressed enough to spend even $100 on that mic. $1000 seems like a scam to me. YMMV. |
May 8th, 2012, 08:29 AM | #4 | |
It tries to make a dummy head mic. without the head - and in a dummy head, the size of the head is important. Inexpensively, you could use two omni mics and a home-made Jecklin disk, which I would prefer to use myself. If I had to record 3D stereo I would use the original Neumann KU100, or a Schneider disk (the Schneider is slightly better than the Jecklin foe 3D on headphones).
John Willett - Sound-Link ProAudio and Circle Sound Services President: Fédération Internationale des Chasseurs de Sons |
May 8th, 2012, 08:57 AM | #5 |
Very interesting replys already. Thank you for weiging in!
Richard, I completely understand what you mean with "3D" sound. It sounds like a gimicky title. And because you have to take into consideration what your end playback medium will be, this is not a "go-to" mic for everyday use. In my daily life, I rarely use stereo for anything. It is a mono shotgun/lav/etc and I have never shot anything that required a stereo mix, so I am not experienced in the subject. I will have to do more research into this binaural recording idea. To my untrained ears, the Mitra in the video did sound better (clearer, and more detailed) than the shotgun, but I also understand the variables in that kind of "test" are infinate. I am asking less for my personal use, more just to get a professional's opinion on that type of recording device. If you were asked to record a binaural stereo recording, how would you do it? |
May 8th, 2012, 10:32 AM | #6 |
There where and probably still are experiments with 2-channel 'spectral' recording which allegedly captured up/down information, however in this case, I suspect it's just a 'buzz-word' scam. They probably sell "Digital Batteries' too.
May 8th, 2012, 05:01 PM | #7 |
The product description says:
"The heart of 3D Mic Pro is a patent pending audio signal processing system SHEM..." I wonder whether that's similar to "sham." I also note that they have a special "3D mic boom pole." In fact, I would think that all boom poles are, in fact, three-dimensional, since it's impossible to construct a solid in less than three dimensions. Be that as it may, they don't even bother to list any dimensions for the boom pole. It might be 6" long, or 60 feet long... who can tell? You have to give these guys credit for audacity. Anyone who can mount two red plastic ears in a piece of plastic sewer pipe, and charge $999 for it, is headed for success. A division of the P. T. Barnum conglomerate. |
May 8th, 2012, 05:15 PM | #8 | ||
Now, if they compared their gadget to a Crown SASS or a Neumann KU 100 or even some taper gadget that you stick in your ears. Or even if they had compared it to the built-in stereo mics on the camcorder, we would have something to talk about. But the video was just completely bogus IMHO. Quote:
WHY do we need a binaural recording? (vs. conventional stereo) HOW are we going to use this recording? WHAT kind of post-production work do we expect to do here? WHERE are we going to play this back that makes binaural even viable? Because I don't believe there are legitimate, mainstream, real-world answers to those questions, I don't anticipate EVER needing to record binaural. But If I did need to record binaural, I would get a Crown SASS (no longer in production) or Neuman K 100 one of the few other binaural microphones. Or I would likely make my own using a pair of omnis from my locker and some appropriate mass or baffle in between. All the legitimate binaural recording schemes have some sort of mass between the microphones to simulate your head. The Mitra wouldn't even make my list of candidates for binaural recording. They seem like one of those products that are long on industrial design and marketing, and come up short on actual technology. I am very firmly in the camp of function over form. Perhaps because I am more of an engineer than an artist. YMMV |
May 9th, 2012, 03:02 AM | #9 | |
Second best - use a Schneider Disk and a pair of diffuse-field omni mics.
