Premiere CS5 - Seperating Left and Right Audio Channels at DVinfo.net
Adobe Creative Suite
Old November 15th, 2010, 06:10 PM   #1
Hey Guys,
Really need help, I've searched the Adobe site and can't find as well.
i have footage edited ready to go in a Sequence, however what I need to do now is remove the Right channel audio from a Stereo recording. (Left channel was for the external mic and Right channel was the on board mic, which picked up too much environment sounds and i need to remove).
Is there any easy way of doing this without actually breaking out in the Project panel, only to sync up with the video manually?
Any help would be appreciated.
Thanks in advance.
Ash Varma is offline   Reply With Quote
Old November 15th, 2010, 06:21 PM   #2
Effects > Audio Effects > Stereo > Fill Left.
Old November 15th, 2010, 08:42 PM   #3
thank you so much Adam!
You rock!!!!!
Old November 18th, 2010, 12:00 PM   #4
You can also do
Audo Effects> balance
Bay Area Wedding Videographerwww.reb6studios.com
Sigmund Reboquio is offline   Reply With Quote
Old November 19th, 2010, 03:48 PM   #5
when recording two completely different sources simultaneously I usually do the following immediately after importing into premiere.
select all clips on which you want to break up the audio channels, right click ¸and select modify -> audio channels. Select mono instead of stereo and you'll automatically get two mono tracks on the timeline instead of one stereo track.
That eliminates the hassle of the fill left/right for every single clip (although you can just c/p the effect and do it very quickly)...
Zoran Vincic is offline   Reply With Quote
Old December 7th, 2010, 06:33 PM   #6
Adobe Systems
Additional Resources for Separating Audio Channels
Hi All,
It's Kevin Monahan from Adobe. I work with Premiere Pro Help and Learning, so I'm here to help. Let me know if you have any questions.
There's more information for those wanting to find out more about separating audio channels right in Adobe Help for Premiere Pro. Check these links to read up on the features.
Adobe Premiere Pro CS5 * Fill Left effect, Fill Right effect
Adobe Premiere Pro CS5 * Balance effect
Adobe Premiere Pro CS5 * Mapping source and output audio channels
Kevin Monahan is offline   Reply
